93-94 driver door swap
Old Jan 6, 2012 | 10:18 PM
9402blazerky's Avatar
9402blazerky is on a distinguished road
Default 93-94 driver door swap
I have a 93 and 94 that I want to swap drivers doors on. Putting 94 on 93. I have taken the door pannel off the 94, the kick panel and I have pulled back the gomet but I don't see anywere the wires unplug, so I can pull the wires out to swap the doors. Anyone know were to unplug the wires so I can swap?...Thanks..D
Old Jan 6, 2012 | 11:48 PM
duxtoyz's Avatar
duxtoyz is on a distinguished road
should be in the area ur looking, otherwise follow the wires until u find a plug. wheres the plug on the 94 door? may be the same place on the 93.
Old Jan 7, 2012 | 12:09 AM
Haven't taking tat one apart yet will do so 2morrow or Sun.
Old Jan 7, 2012 | 08:37 AM
atvwarrior's Avatar
atvwarrior will become famous soon enough
You have to disconnect the wiring inside the door then pull it through the wiring hole in the front of the door . I just put 2 doors off a 91 2 door onto my 4 dooor 94 blazer it was a piece of cake .
Old Jan 7, 2012 | 11:32 PM
Thanks for the tip That means I need to unplug dorr lock,window, and all then pull through hole?
Old Jan 8, 2012 | 08:08 AM
atvwarrior's Avatar
yep just that easy it took me about a hour and I also had to switch out a window .
Old Jan 8, 2012 | 07:53 PM
K, Thanks a bunch.
mamawolf70
Apr 10, 2020 10:44 AM
Ryan Johnson
Aug 14, 2014 10:18 PM
MikeTastic
Aug 8, 2012 04:41 PM
greenbean
14
Feb 7, 2010 08:02 PM
jennshea77
Dec 4, 2006 11:07 AM
