Try heat and a scraper/ wire brush.
Originally Posted by cleburne red
(Post 597302)
I like the idea of going back to simple with a carb, but where do you live that it's legal to do that? Or will this just be an off road toy, so you don't have to worry about vehicle inspection? Around here anything less than 25 years old has to pass emissions.
I would love to ditch all the electronics on my '95, but I wouldn't be able to get the thing inspected. |
Originally Posted by Rjay
(Post 597367)
2 Attachment(s)
Well, the interior is about done. Waiting on a second set of hands to come over and help remove the brakes, steering column, and headboard. That should do it for the inside.
I will start taking out the gas tank, transmission, and transfer case tomorrow. If I have time after that, I will gut out what I can in the engine compartment. |
How long dis it take you to pull the dash and climate controls? Are you gonna put the AC back in?
4 Attachment(s)
With the help of a friend, a few large cans of red bull, and motivational music blasting....for the entire dash and heating/ac unit removal took about 2.5 hours.
I will not be using the factory heater or AC. I will be using the AC compressor for a on-board air compressor conversion, and for heat I will be using a Maradyne Stoker Heater. The unit is only 7.5" H x 11.5" L x 8.7" D, compared to the original one (see attached photo). The original dash is now junk and I will be doing something like this: https://blazerforum.com/forum/attach...4&d=1377441666 |
After I get off a few more rusted on nuts and bolts, and get a few components out, I should be good to go on taking the body off. If anyone has done this, would you know if a few saw horse style brackets with 6X6 cross beams be ok to hold the body up? Keep in mind that the front fenders will be off, along with the hood and doors?
Once the frame has been blasted and coated with POR-15, the rebuild should go much faster. |
