95 to 98 headlight conversion
Old Feb 16, 2012 | 03:37 PM
BahamaBlueBlazin's Avatar
BahamaBlueBlazin is on a distinguished road
Default 95 to 98 headlight conversion
Last week I was pulled over for a burned out headlight on my 1995 blazer. Thankfully I was given a warning and sent on my way. This got the ball rolling for doing the headlight conversion that I have wanted to do for a while now. I went to the junkyard and got a chrome bumper, valence, grille, and headlights off of a 1999 blazer all for $140. Sorry if the pictures aren't the best quality, I was too lazy to get my DSLR camera out so I just took the pictures with my phone.
This is what it looked like when I started:
Once I removed the grille and bumper:
Hood and lights removed:
I loosened both fenders and removed the radiator support
Out with old:
In with the new:
Old Feb 16, 2012 | 03:43 PM
I removed my air bag sensors and bolted them to the newer support:
Before I put the newer radiator support back in I gave it a quick coat of paint:
New rad support installed:
Chrome bumper installed and headlight wiring with 10ga wire and relays
And finally everything mocked up
Things left to do:
New headlights (the ones from the junkyard are broken beyond repair)
Fabricate/ bend bumper support brackets
Get new bulbs (hopefully LED)
Old Feb 16, 2012 | 04:46 PM
xgiovannix12's Avatar
I like !
Old Feb 16, 2012 | 05:59 PM
tibby's Avatar
Default .
I'm going to be doing the same thing with my '96 soon. How long has everything taken you so far? How bad was it to switch out the headlight wiring to a thicker gauge with the front end apart?
Old Feb 16, 2012 | 06:02 PM
melliferal's Avatar
melliferal is on a distinguished road
I'm going to have to do the same thing to my Jimmy here eventually.
If you don't mind: how easy was it to loosen those fenders? What more would you have had to do to remove one completely? I'm not asking for a procedure, just a general impression. Is the whole job the piece of cake it looks like? How long did it take to complete (minus paint-drying time)?
Old Feb 16, 2012 | 09:29 PM
tibby's Avatar
Default .
This: Click on the brackets ----> []
Old Feb 18, 2012 | 07:44 AM
I have spread out the work over 4 days working around 2 hours a day; so a combined 8 hours. Within the first two days I had the old radiator support out and the newer one in. The other two days were spent fumbling with the wiring and final touches. I used two threads from S10 Forum to help me figure out the wiring. Once I figured out what I was doing, the wiring was fairly simple.
Headlight Rewire (Sealed Beam)
Headlight Rewire (98 and newer)
Loosening the fenders is very straight forward. I removed around 10 bolts (don't remember how many exactly) that surrounded the fender. Then removed all the bolts that held the inner fender/splash guard to fender. If you still have questions let me know and I can do a write up with pictures on how to remove a fender.
Back to a little progress, I got new headlights
And if someone is interested in converting sealed beam lights to composite this is a How-To I found on S10 Forum
How-To Convert Sealed Beam To Composite Headlights
Old Feb 18, 2012 | 09:06 PM
tibby's Avatar
Default .
Okay, hopefully my install will be a little quicker because I'm already running composites and the new front end have composites.
Old Feb 19, 2012 | 12:44 AM
melliferal's Avatar
Excellent! Ta muchly.
Old Feb 19, 2012 | 11:42 AM
Brian_D's Avatar
Nice freaken job man!! looks way better!
