96 SFA Swap
Old Nov 30, 2012 | 04:06 PM
KM346's Avatar
KM346 will become famous soon enough
Originally Posted by Diaita
the sure way to find the case you need is from a 93-94 s-10 truck or blazer 4wd. it will have a u-joint front output on the transfer case and a NP231 on the round ID tag on the back.
True that... the t case in my truck is a 233 from a 94 blazer. Same encoder motor as the 2nd gen electric shift, and has a fixed output and the stronger 1.25" chain and gears. All i had to do was swap the jeep yoke on and i was ready to go.
Old Nov 30, 2012 | 04:07 PM
jbb421's Avatar
jbb421 is on a distinguished road
Just got back from getting my axles... mygod i wish i had had the towmotor at my house the front axle has to weigh ~ 400+ lbs lol heres some pics.
Ok awesome... guess ill go pick that up tomorrow and just got word back from ord gonna be ordering that monday if i get the heads back on this car in time.
also how can i tell what spline these axles are... not very familiar with axle work i was looking on autobone last night for locking hubs and it said 19 spline for the year and model i got these off of......
Attached Thumbnails 96 SFA Swap-img_20121130_151840.jpg   96 SFA Swap-img_20121130_153735.jpg
Old Nov 30, 2012 | 04:24 PM
oldsbravada2000's Avatar
oldsbravada2000 is on a distinguished road
I have talked to Will at Off Road Direct, they will make you a kit if you are interested and are willing to pay a little extra. That is for the leaf spring setup. I'm not sure about the coil spring setup.
Old Nov 30, 2012 | 04:28 PM
jbb421's Avatar
Well @ their site it says that the kit i need is instock and i sent them an email, and they said they were instock. so i guess all is good
Old Nov 30, 2012 | 04:29 PM
Diaita's Avatar
internal axle shaft spline is 30 spline, outer hub spline is 19. if you are looking to get rid of the full time 4wd on the front axle, 1/2 ton Ford or GM locking hubs will fit it if i remember right.
Old Nov 30, 2012 | 04:38 PM
Diaita's Avatar
oh, forgot that part... the NP233 is an electronic shift transfer case, and the NP231 is a manual shift transfer case. If all you can find is the other transfer case than what you have, the front output shaft does interchange.
Old Nov 30, 2012 | 06:27 PM
jbb421's Avatar
Mile Marker/Hub (4 Wheel Drive) (423) | AutoZone.com those will work right... or should i just spend 30 bucks more and get warns...
Also my tcase is manual shift, and what year Cherokee any?
Thanks again to all of you for the input.
Old Dec 1, 2012 | 08:19 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
I can't wait to see how this turns out for you , Good luck . It was the best thing I did all winter last year , I love the way my blazer looks and drives now . Tomorrow I have a friend coming up with his new blazer , its a 89 2 door SAS but not lifted , its built for hitting jumps / tuff truck . And if theres ever anything I can help with please ask .
Old Dec 1, 2012 | 09:29 PM
Zanders's Avatar
Zanders is on a distinguished road
EDIT: I'm dumb and didn't see page two
Old Dec 2, 2012 | 02:03 AM
jbb421's Avatar
Thanks for that atv... I might just have to hold you up to that lol. Its cool Zanders.
Since my rear axle didn't come with drums/half the springs, and a bent backplate i'm thinking i will be cheaper off to go with converting it to disc. Now i would like to know if i could rob all of this off a gm 10bolt and rig up a bracket for the calipers or will i need a conversion kit. Not much progress yet just been tinkering with the axles replacing the bad/prepping them for paint.
