99 Bravada (Trail Edition)
Old Aug 9, 2012 | 01:28 PM
  #41
Irocz327's Avatar
Irocz327 will become famous soon enough
So it's been awhile since I updated. Iv ordered all the gauges, fuel pump, wires & plugs for the wynjammer. All that's left is to order the kit from al didn't get a chance before my honeymoon. So I'll be ordering that this week. Other wise I picked up a dual speed single fan from the pick & pull so I need to order the controller so I'll be doing the major install hopefully soon depending on time management.
Ill post pics of the gauges & pod. Later tonight.
Edit: I have Pics!! Won't load so link to my Photobucket
Links to the Gauge Site.
Boost Gauge
Wide-Band Kit
Trans-Temp
Direct fit A piller 3 pod
Old Sep 18, 2012 | 10:38 AM
  #42
Irocz327's Avatar
Currently I've got the gauges installed except for the o2 sensor for the wideband. I'm at a stand still right now while I'm waiting on job offers. :/ so hoplefully before xmas I'll have the supercharger ordered & installed.
Old Oct 17, 2012 | 08:42 PM
  #43
ZOMBIESLAYER001's Avatar
ZOMBIESLAYER001 is an unknown quantity at this point
Default Question on Bravada
Hey man i have a 2000 Oldsmobile bravada and trying to find a way t flift it may i ask you how you lifted yours it would mean alot since ive tryed to find things to lift this with.
Old Oct 24, 2012 | 06:07 AM
  #44
Irocz327's Avatar
I started with a tbar crank & 2in shackles. Now I installed the rc2.5 suspension lift & a 2in pa body lift. Any lift that fits blazer on the same year will fit a bravada.
Old Oct 25, 2012 | 05:25 AM
  #45
Oh so basically mostly T-Bar n the rough country 2.5. Did you have to change your transfer case to 4x4? Or just left it all wheel the only reason I'm asking is cuz I need to get advice from someone who lifted a bravada cuz by me it's rare there isn't one I wana be the first but I appreciate your help n what not
Old Oct 25, 2012 | 06:26 AM
  #46
Irocz327's Avatar
If you wonna do a the rc2.5 just do it bucuase the trucks look wierd with just a tbs crank & no shackle. I'm planing on swapping in a np233 & converting it to a manual in the spring. Hopefully by this weekend I'm gunna be swapping in a blazer front diff & doing the posi lock mod. & just leaving the transfer engaged all the time.
Old Oct 25, 2012 | 02:58 PM
  #47
That the weird things tho alot of people tell me to change out the transfer case to a blazer 4x4 because some reason Idont remember what they where saying but I'm defiantly doing the RC 2.5 with tBar crank n shackles body lift n I should be set the only problem I will have is when I upgrade the tires cuz of the smarttrak the mph will be off but Ill deff look in to that
Old Oct 30, 2012 | 05:54 PM
  #48
Irocz327's Avatar
Sorry I read thru fast last time. Anything that'll fit a blazer suspension wise will fit a bravada. I have a 2in PA body lift & the rc2.5 lift & haven't had any problems. Yea my mpg/speedometer is off because I'm on 31s. You could do a ECM reprogram & have them adjust for larger tires. I'm gunna be getting a wynjammer when ever I get my army bonus & it include a new ECM & I'm gunna have them adjust it. I you have any more ?s hit me up.
Oh & the bravada s only have a "high" gear no low that's why ppl say to change it. I'm just setting my up this way to have controllably 4x4 for the winter. Gunna do the t case swap in the spring.
Old Nov 18, 2012 | 06:05 PM
  #49
oldsbravada2000's Avatar
oldsbravada2000 is on a distinguished road
That wynjammer setup will be pretty bada** NEVER seen a bravada with one. To get selectable 4wd you can switch out the front end and do the posi-lock cable mod. You could also swap out the transfer cases for one out of a blazer but how would you shift it? This guy figured it out - Zr2USA.com > How to: Manual 233
If you want to use a np231 from a first gen s10 with a manual shift lever you should check out this thread, it will answer all your questions. I am doing the first gen s10 swap soon. - https://blazerforum.com/forum/builds...x4-swap-42803/
EVERY SINGLE LIFT for Blazers and Jimmys WILL WORK on Bravada's with NOO complications. EVERYTHING bolts onto a bavada the SAME way as a blazer or jimmy. The transfer case AND the front diff have the SAME mounting points just different guts.
Old Nov 24, 2012 | 01:45 PM
  #50
Irocz327's Avatar
I bought an np231 off a buddy the other day out of a 89s10 & both front & rear driveshafts for 300. A buddy is gunna help me rebuild the internals since I've got it out of the truck & then ill build a "BF232" & then it's just a matter of figuring out the linkage since I already have a floor shifter.
I'm holding off on the S/C for right now because of financial issues.
I can remember if I updated but I put a 3.73 front diff out of a 04 Sonoma jn a few weeks back. I'm gunna do the posi lock mod sort of but I'm gunna do a vacuum solenoid like the mod Gio did in his truck.
