advice on front leaf spring bending wrong way
Old Jan 15, 2011 | 10:27 PM
green.wesley@att.net's Avatar
green.wesley@att.net is on a distinguished road
Default advice on front leaf spring bending wrong way
I own a 86 k5 and recently I added some lift with shakles on the front. Doing this made the front left spring bend the wrong way an advice?
Old Jan 15, 2011 | 10:36 PM
AJBert's Avatar
Get stronger springs?
Old Jan 16, 2011 | 05:52 PM
awbolton66's Avatar
awbolton66 is on a distinguished road
checked to make sure none are cracked
Old Jan 16, 2011 | 05:58 PM
Red 96''s Avatar
When you add longer shackles on your leafs, it increases the pressure on the spring causing it to bend more. When I put shackles on the back of my Jimmy, the leafs became almost completely straight. I don't know how many miles your springs have on them but chances are, they may just not be as strong as they used to be. Maybe get a new set or look into and add-a-leaf?
Old Jan 26, 2011 | 08:30 AM
gopher_6_9's Avatar
gopher_6_9 is on a distinguished road
All k-5 1/2 tons I have ever owned had negative arch front springs. That is why swapping in rear leafs to the front gives you the 5" Lift.
My bet is that it is no more negative arched now than it was before, you just notice it a little more, you do know that a 2"inch longer shackle will not give you 2" of lift right?
My advice:
Depends on what you are going for, if it was me.... If you want a reliable good riding suspension to run 33-35" tires then do the rear springs in the front, scrap the sway bars, shackle flip in the rear, replace the shocks on all 4 corners and go high steer. It will flex like a 13yo russian gymnast and ride like a caddilac.... I fit 35's that way NO PROBLEM on my 89. Drove it every day I wasn't working, could have drove it to work no problem (55 miles each way), but the highway drive never was that great on it, it always wanted to wonder, and the gas milage sucked.
devlinmcguire
Dec 1, 2012 09:22 PM
musclemasterflex
Suspension Tech
Aug 26, 2011 09:10 AM
tri94bbc
May 6, 2011 10:22 PM
kyle123
Apr 3, 2010 05:13 PM
S10Blazer
Nov 9, 2007 08:08 PM
