Another SAS Build
Another SAS Build
Hey yall so im currently doing a SAS on my 2001 chevy blazer. I haven already swapped strip the hole IFS from the front and removed the rear axle. Im currently working on swapping my new TC. I went from a np236 to a np231c manual selector.
do any of you know what i do with the electrical that goes to the np236 i took out ? I know i only need one speed sensor for the np231. But the np236 has 3. Do i just delete them along with the shift motor ? Thanks in advance
I don't know if there's any way to make it stay off. You might possibly be able to remove the TCCM, then flash the PCM with a tune from a manually shifted truck. I chose the bulb modification route.
