Baby Semi Build
Thanks I finally got my fender flares to stop rubbing =P they needed to be grinded a little more
gotta love a dremel always handy to have one
it only rubbed when i did sharp turns and hitting a bump at the same time
Looks like you wired them just into a switch in the cab. I like the ones from Bully Dog I think that have a 3 way switch - either manual on or off or on with the reverse lights.
Still look good, what wattage are they?
i got a relay on them there the ones you put on heavy equipment but there 12 volts ill check tomorrow for wattage
there way brighter in person then on the picture
i think the picture came out bad ill try to take a better one facing a wall or something
I mean its enough for what i need them for
if someones in a ditch or stuck
or when i hook up my trailer
and some other stuff
just incase you are still thinking about adding a set of side pipes.
found these while stumbling through E-bay not really looking for anything specific.
New Chrome Side Pipe Exhaust System, 70" Long Pair | eBay
small update : I got my cluster fixed, Also fixed my horn fuse melting turned out to be the alarm .
Next project : Icm module , Wash/wax , 4x4 front end cable
also i might add id lights under the tire like the heavy duty trucks have
Its your baby but I'd put a hood ornament on your rig.
you probably have better things to spend your money on.
Peterbilt Hood Ornaments | IOWA80.COM
