BDS 5" Envoy lift
Old Mar 19, 2013 | 06:38 PM
  #61
okiedoak20's Avatar
PJ, you know i have always looked at your sig pic of your ride going up the rocks but never noticed that there is a winch mounted under the bumper..
that is just plain ol cool, and looking at the post with your ride next to the
little truck thats when it just jumped out at me. that is just a great idea..
Old Mar 19, 2013 | 06:46 PM
  #62
okiedoak20's Avatar
Ok, so breifly about the rear vibration, why would the drive shaft need to be balanced if it was the same one I was using and it wasn't vibrating before? The same for the U-joint?
Old Mar 19, 2013 | 07:06 PM
  #63
Diaita's Avatar
The u-joint will have a wear pattern that it gets over time, when you lifted the rear, you increased the driveshaft/u-joint angle it is wearing in a new, wider pattern now.
With the lift shackles, you may not have the correct pinion angle, causing vibration.
Old Mar 19, 2013 | 07:27 PM
  #64
okiedoak20's Avatar
Oooh, i see... did not know that..
Old Mar 19, 2013 | 07:29 PM
  #65
okiedoak20's Avatar
ok so i will go and buy a new U-Joint, I just remembed i have a life time warrenty on that puppy,
Old Mar 19, 2013 | 07:34 PM
  #66
warthogdriver's Avatar
yeah, no comes all the little tweaks this install will require.
nothing major, but each ride is different. i dont regret my decisions....but i wish i knew all the things that i had to chase down.
Old Mar 19, 2013 | 07:49 PM
  #67
okiedoak20's Avatar
al right lets pick at everyone knowledge here..
ZR2 axle 8.6" i think it a 2003 year, the u joint is different i think from a
non-ZR2 7.6" is there a way to use the yoke from the non zr2 axle on the zr2 axle?? or to get a u-joint with two end caps one size for the zr2 axle and two caps for the non zr2 axle...
Old Mar 19, 2013 | 07:55 PM
  #68
pj5454302's Avatar
Thanks, The sig pic is real old (aug 2010) thats why you cant see it.
Speaking of things not on the sig pic, Recognize the headlights?
And the envoy is looking real nice.
Old Mar 21, 2013 | 05:25 AM
  #69
okiedoak20's Avatar
You know this whole lift thing is sorta like giving my car a boob job!!!
Old Mar 21, 2013 | 08:50 AM
  #70
El_Beautor's Avatar
It certainly does bring out the urge to caress it.
Did you get your u-joint and vibrations resolved?
