blazer v8 swap n tcase ?`s
Old Feb 12, 2011 | 01:26 PM
dblok4eva's Avatar
dblok4eva is on a distinguished road
Default blazer v8 swap n tcase ?`s
ok im thinkin of gettin this 98 blazer. ive done the v8 swap a couple times no problem. what im wondering is i have a nv3500 trans mated to a np241 tcase. i got a saw zall so im not scared to do some moddin but with the front and rear driveshafts, will they work? will the 241 work with this truck if i did the floor cutting for the shifter handle? im open to any suggestions, ideas. gimme ur thoughts.
Old Feb 13, 2011 | 10:48 AM
abig84's Avatar
I used a 208 case which is basically the same sized just reversed. Only problems I had was the cat was in the way and I just cut a hole in the floor for the shifter handle. I used the same rear shaft but had one for a k5 lying around for the front cause I used k5 axles
atonyatm
Feb 2, 2015 08:06 PM
91chevywt
Mar 24, 2010 09:24 PM
rudolf
Sep 7, 2008 09:14 AM
rudolf
Sep 6, 2008 01:01 PM
ironclad
Aug 18, 2008 04:05 PM
