need help with tcase!!!
Old Sep 6, 2008 | 12:56 PM
rudolf's Avatar
rudolf is an unknown quantity at this point
Default need help with tcase!!!
Have a 2002 blazer(not zr2) lights on the dash works fine but 4 wheel drive dont engage. I went wheeling and suddently 4x4 didnt work no noise nothing.Can someone help me.
Old Sep 6, 2008 | 01:04 PM
Default RE: need help with tcase!!!
This topic has been covered in many posts.
You need to determine if the transfer case is not shifting properly or if the front axle is not engaging. To keep from repeating things, please try some searches and ask back if you still have questions.
Old Sep 7, 2008 | 03:42 AM
rudolf's Avatar
sorry abouy the double tread. Found the problem nothing to do with not shifting or front diff. The vacuum line was leaking. Yes i went thru all your reply thanks. thx for helping.My blazer runs in South Africa and its doing realy good here in the mountains.
Old Sep 7, 2008 | 09:14 AM
Glad you found your problem. If you had a vacuum leak, it was causing the front axle not to engage.
91chevywt
Mar 24, 2010 09:24 PM
gil
Jan 28, 2010 09:26 PM
aaron81182
Jun 1, 2009 05:13 PM
rudolf
Sep 6, 2008 01:01 PM
ironclad
Aug 18, 2008 04:05 PM
