Blaz's 05 blazer
Old Sep 4, 2014 | 07:58 PM
  #181
rexmburns's Avatar
Super Moderator
It'd be hard to convince my wife to go north lol!! She likes to go south to the beach.
Old Sep 4, 2014 | 08:06 PM
  #182
Jamaroon's Avatar
We have beaches!
those are some damn fine looking shock tower mounting plates lol
Old Sep 4, 2014 | 08:33 PM
  #183
blaz's Avatar
blaz is on a distinguished road
Did you have something to do with those?
Old Sep 5, 2014 | 09:49 PM
  #184
247monster's Avatar
Aaaah ha ha
Cant stop drooling over this build lol
Old Sep 5, 2014 | 10:18 PM
  #185
Jamaroon's Avatar
Yeah, I seem to recall whipping something up lol
Old Sep 8, 2014 | 10:38 AM
  #186
Jamaroon's Avatar
And for your viewing pleasure
This is the view from inside my Sonoma
4" more ground clearance at the frame than my Blazer and 5" more than my Sonoma
Attached Thumbnails Blaz's 05 blazer-9a9ec8e3-4daa-415f-a2a3-082339531860_zpsz3vriljf.jpg   Blaz's 05 blazer-dfb9f1d7-00d9-46bf-bdf8-725d25201a92_zpswcdkpvzb.jpg
Old Sep 18, 2014 | 09:15 PM
  #187
blaz's Avatar
The major work is done now it all the little things.
Exhaust needs to be modified to clear the front driveshaft.
The transmission crossmember needs to be modified to clear the front driveshaft.
Need to buy a tuner to fix the speedo. (recommendations are welcome)
Relocate steering stabilizer.
I found a jeep front driveshaft that is 28" collapsed and 31 " extended. It will be really close, so I rebuilt it because the U joints were bad and the front driveshaft will spin all the time with my current set up.
Parked beside a stock ZR2.
U joints and centering ball I removed and replaced.
4 Door driveshaft that I have shortened to the correct length since the lift. U joints on the rear shaft are running at 15 degrees which is max angle from my research. I will rethink the rear shaft if I have any issues in the future.
I also picked up a 10 " drop hitch to pull my little utility trailer. I don't think I want more drop than this.
Attached Thumbnails Blaz's 05 blazer-20140911_154805_zpsm5jkfvry.jpg   Blaz's 05 blazer-20140911_154915_zpscfrhbld9.jpg   Blaz's 05 blazer-20140916_140232_zpsw8xczpwl.jpg   Blaz's 05 blazer-20140916_140150_zpsbwkfnysp.jpg   Blaz's 05 blazer-20140916_140200_zpsgygqwjgd.jpg
Blaz's 05 blazer-20140916_140217_zpsqiymdxc4.jpg   Blaz's 05 blazer-20140918_192157_zpsncvpfy87.jpg
Old Oct 10, 2014 | 10:19 PM
  #188
blaz's Avatar
Cross member was modded slightly to fit the driveshaft as was the exhaust. I will redo the exhaust system with something more high flow when I get extra cash.
I relocated the steering stabilizer before going out last week end.
Attached Thumbnails Blaz's 05 blazer-20140922_154021_zpspjcr7hg8.jpg   Blaz's 05 blazer-20140922_154011_zpsk2tb9nsr.jpg   Blaz's 05 blazer-20140922_154004_zpsgs5vjhcp.jpg   Blaz's 05 blazer-20140929_204138_zpspkt57djb.jpg   Blaz's 05 blazer-20141003_143427_zpspqhvxzbh.jpg
Blaz's 05 blazer-20141003_143437_zpsckdz1xrs.jpg   Blaz's 05 blazer-20141003_143449_zpstnxlwmip.jpg
Old Oct 10, 2014 | 10:36 PM
  #189
blaz's Avatar
Went out for a trip last week end and the blazer did well, it will do better when I learn more about the SAS. I need to bump stop the front and rear, limit strap the front and put in a swaybar for the hiway driving.
One of Jared's blazer
Attached Thumbnails Blaz's 05 blazer-dsc00954_zpszynz6dcx.jpg   Blaz's 05 blazer-dsc00955_zpskc4hc8ml.jpg   Blaz's 05 blazer-dsc00956_zpsjbchtp0w.jpg   Blaz's 05 blazer-20141004_173937_zpshtkw8gth.jpg
Old Oct 10, 2014 | 10:44 PM
  #190
blaz's Avatar
I has a slight problem with my front springhanger/crossmember design.
I removed the bent 1/4" plate and beefed it up.
First pass.
Capped.
I didn't take a picture of the gussets on the bottom, but it looked like this.
Attached Thumbnails Blaz's 05 blazer-20141006_184132_zpsb5qr2ofp.jpg   Blaz's 05 blazer-20141006_195251_zpsd4rejh6a.jpg   Blaz's 05 blazer-20141007_201007_zpsz1ljejg0.jpg   Blaz's 05 blazer-20141007_203105_zpsjh8tfefx.jpg   Blaz's 05 blazer-20141009_193858_zpsbzp5walm.jpg
