East German Blazer Rebuild and customizing
Old Oct 31, 2012 | 03:13 PM
  #141
christian1984's Avatar
christian1984 will become famous soon enough
Now, the Blazer is in the warm garage an waits for the winter.
I want to remove the vacuum 4x4 switch and this s**t. Find some good manuals for installation for the np233 manual conversion. But I donīt want to install a posi-lok. I want to replace the vacuum actuator by a solenoid like on K2500 or similar.
So, I want to remove the hood, the Battery Tray and measure the way of vacuum actuator and compare it with the way of the solenoid of the front diff solenoid of my buddys K2500.
Old May 19, 2013 | 01:34 PM
  #142
Default 4x4 Conversion complete
Hi Guys.
A long time I wasnīt here.
The reason was my 4x4 Conversion.
I have had to check, what does not work, how can I fix it and whatīs the most useful construction.
Iīve seen, that the transfer case work, but the front axle doesnīt locked in.
the vacuum hoses were worn, and I wonīt use them longer.
So, I got got the idea, to use any other Actuator.
At least I get the Actuator of aī93 K1500 Pickup of my buddy. This Actuator have a plug with 2 wires, so it was good to regulate.
I designed a bracket and a cylinder with a slider where the shifter cabke is fastened.
Here some pictures of the 3D-Model:
The bracket ist mounted at the same position of the stock vacuum actuator bracket.
I made some cables to the middle console and a Killswitch to regulate the actuator.
Here are some pictures.
the position in the passenger side fender
the shifter cable (red arrow) and the slider (yellow arrow), where the shifter calbe is fastened
Today I already installed it all and made some test.
And it work great, was cheaper and looks better than the Posilok-parts.
And it was made by myself.
So, I am a little bit proud to make a useful conversion to remove the vacuum actuator.
btw I changed all vacuum hoses and placed them near the transmission vent valve with some sintered metal filters.
I hope you like my conversion.
Attached Thumbnails East German Blazer Rebuild and customizing-3d-modell_15bytg.jpg   East German Blazer Rebuild and customizing-3d-modell_25hasr.jpg   East German Blazer Rebuild and customizing-3d-modell_39eb1l.jpg   East German Blazer Rebuild and customizing-img_2526-kleinwhzjl.jpg   East German Blazer Rebuild and customizing-img_2528-kleinknann.jpg
Old May 19, 2013 | 05:11 PM
  #143
RobR's Avatar
RobR is on a distinguished road
Great job on fabrication and the build. Excellent work!
Old May 19, 2013 | 11:06 PM
  #144
RangerG's Avatar
That's very cool!!
Is that a solidworks model? Do you do CAD as a profession?
Old May 20, 2013 | 02:49 AM
  #145
Yes, thatīs SolidWorks and i do it as a profession.
I made these models at my last company.
In my new company we use inventor.
Old May 20, 2013 | 11:38 AM
  #146
RangerG's Avatar
Awesome!
I have inventor at work too but I'll mostly be using some piping modeling programs like CADWorx.
Steinbruchsoldat
Mar 29, 2017 09:36 PM
Kipper667
Aug 23, 2013 11:50 AM
Mczuk
Sep 13, 2012 08:15 PM
monette999
Mar 11, 2012 09:34 PM
88s10Blazer
Jun 19, 2006 06:50 AM
