German 98 Blazer build
Old 02-27-2011 | 02:41 PM
Steinbruchsoldat's Avatar
Steinbruchsoldat is on a distinguished road
Sent you a pm...
Just bought this for about 3$, let`s see if i can make it work...
  #232
Old 03-02-2011 | 01:15 PM
Damn, I`ve got a big cooland leak at the back of my engine. Not sure where it`s coming from...
Any suggestions?
  #233
Old 03-02-2011 | 02:55 PM
Moores12345's Avatar
Moores12345 is on a distinguished road
Water pump?
  #234
Old 03-02-2011 | 03:05 PM
Is on front of the engine...
  #235
Old 03-02-2011 | 03:31 PM
PaulO2288's Avatar
PaulO2288 is on a distinguished road
I feel like your truck weights 10,000lbs now lol. Hows the power and gas mileage with the larger tires and all the weight?
  #236
Old 03-02-2011 | 03:33 PM
old skool luvr's Avatar
guess he didn't notice you said @ the back.
sounds like it might be the lower intake manifold gaskets have let go. might even be the head gaskets. most times a head gasket fails, it'll cause alot of white "smoke" (steam) out of your tail pipe. kinda hard to tell @ this time of year, but once it's up to temp & the exhaust is nice & hot, it'll still have the same amount coming out as when the engien was cold.
you can cover the engine in flour (well, just the back) it'll make it easier to trace the source of the coolant.
  #237
Old 03-02-2011 | 03:36 PM
Hi,
i can tell for sure that it`s not a headgasket... Is there any coolant line at the intake? Or why could it be the intake gasket?
It looks like it`s coming from under the distributor...
My engine is all covered in mud, so it should be easy to track the coolant. Problem today was that it was spread all over due the driving...
It`s around 13-14mpg mixed driving. But hey, who cares if the fuel is about 10$/gal?
  #238
Old 03-02-2011 | 04:20 PM
this just hit me......the hoses for the heater core are right in the middle of the firewall.................
should check to make sure there isn't anything wrong with that. man, i sure hope your heater core didn't crap out on you. that's a major job if it did.
wait....didn't you mention you just replaced that? maybe the hoses aren't tight enough.
  #239
Old 03-02-2011 | 04:48 PM
Hmm, did nothing on the heater core. But that sit`s in the dash, doesn`t it?
The hose connections at the firewall looking fine, the water is coming from the engine for sure...
From my research i assume it`s maybe coming frome the intake gasket...
  #240
Old 03-03-2011 | 07:07 AM
This is live from the shop...
The coolant is coming clearly from the intake gasket:
As it sits now, after 3hours of work:
This is the broken gasket:
Ok, back to work now...
Quick Reply: German 98 Blazer build
