German 98 Blazer build
Old 02-16-2011, 01:11 PM
Steinbruchsoldat's Avatar
Steinbruchsoldat is on a distinguished road
If your shocks broken then it`s not a problem. Just use an angle grinder and grind them out.
Pressing it in in the new ones is no problem...
  #212
Old 02-16-2011, 03:04 PM
Benedict1337's Avatar
good idea... how do you like the air shocks? I was thinking about getting a set
  #213
Old 02-16-2011, 03:21 PM
They`re great so far...
I`ve about 100psi in them, they`re able to take 200psi, so there`s much capability left. The ride is fine, even a little better than before...
  #214
Old 02-17-2011, 10:09 AM
pj5454302's Avatar
benedict
You can get airshocks from autozone that come with the upper brackets. If you get the shocks from a fullsize truck you will get even more lift and have a longer shock for flexing.
  #215
Old 02-17-2011, 10:39 AM
do you need a special kind of compressor or anything to use them?
  #216
Old 02-17-2011, 11:25 AM
No, it`s the same valve like on the tires. You can pump them to about 140psi, so if you have a compressor that pushes that it`s fine...
I have mine at about 90psi right now...
  #217
Old 02-18-2011, 12:39 PM
Installed my new blend door actuator, but it didn`t work. After I opened the cases, i saw why:
Left one is the new...
Not sure what to do with that damn thing...
  #218
Old 02-19-2011, 09:37 AM
Remounted the washer tank today:
Also installed the new rear wiper motor today. The new one didn`t work too. You can hear the motor spinning, but the gears are broken.
That`s the second spare part from 4 that don`t work...
  #219
Old 02-19-2011, 06:52 PM
Moores12345's Avatar
Moores12345 is on a distinguished road
Good location for the windshield washer fluid, I'll have to do that too when I make my snorkel.
  #220
Old 02-19-2011, 06:58 PM
Hmm, i don't think it'll fit with the 2" bodylift. It's really close to the hood on mine, i even had to trim the bottle on the lowest mount...
Quick Reply: German 98 Blazer build
