German 98 Blazer build
#271
I believe the speed sensor is on the tail shaft of the transfer case.
you can kind of see it on this pick.
#272
Thanks for the pics.
I`ll check tomorrow if it`s the Vss. If it`s bad, then my obd reader shouldn`t get a speed signal. If it get`s a signal then it`s the speedo itself...
I`ve read that the vss works with various resistances. Do if a wire is broken the speedo reads unlimited resistance and is at full speed. Maybe this could be the problem too?
#273
No idea. But those vss are $5 here used. No idea what they are new.
#274
This was an easy fix. I just disconnected the battery over night and this morning the speedo just worked normal...
#275
Made my own lift mate today. Started this morning with those parts:
A little grinder action:
All welded up. I couldn`t get any nice welds today, not sure why...
Test:
After this test i realized that i forgot the bolt that holds the second strap, so it actually hang on only one strap...
The paint is drying right now, more pics when it`s finished...
Test:
#276
looks good,if i ever get stuck to where i need one of those jacks ima gonna use my winch,you sure came along ways on this truck,hows that intake gasket holding up?
#277
Hi,
there are lot`s of situations where a winch is absolutely useless. The I use my hilift or the air jack. Sand ladders and a pull pal still missing...
The intake gasket is holding up fine...
#278
Today i added a sticker of our german board:
Then I started with a tree removal in our backyard. This tree had to go:
Cut down:
My car with all the limbs inside and on the roof rack:
Then i hooked it on my winch and started pulling:
Result:
Was a fun day...
Cut down:
Result:
Was a fun day...
#279
nice!!! I want a winch so bad. I like the mod to the high lift too
#280
The finger at the completion of your projects are becoming like a sig.
Always makes me laugh.
