German 98 Blazer build
She looks sad without the winch...
Ok, the manual nv233 is finished:
The slot for the shifter:
The shifter "linkage"
Added a little bling. This shift **** was in all my previous car`s, so i thought I`ll put it in the blazer too:
That bracket prevents the linkage from coming off. I think it`s not necessary but I feel better with it:
Now I`ll try to repair the winch...
Hi,
it turned out that the shut off switch i put in the in the winch wiring died...
The horns sound ok, but when my air system is finished I`ll put a train horn in there...
The manual shifter controls LO and HI. I already have a switch for 4WD...
Got the rear swingout started today. Used an old engine hoist for it...
Mockup:
Welded up:
There will be a fullsize spare on the left and two jerry cans on the right. Maybe a ammo box too...
Also did the quadbeam mod...
Mockup:
Welded up:
I have a 98 4 door and I just put Cragars on it (15 x 8 and 4'' backspacing). It rubs on the back of the fender in the front on some turns, like in and out of the drive way. Should that stop when I lift it 2''? I was planning on putting 31's x 10.5 on it but it think that will make it rub again. I guess the real question is do I have to cut my fenders, and if so where did you get those flares?
The fender flares on his truck are stock GM flares. They were only available outside of North America. There are a couple people here from New Zealand and other parts of Europe that have them. Everybody wants them.
