Jamaroon's ZR2
Old Sep 16, 2012 | 01:48 PM
  #61
Jamaroon's Avatar
So Paul and I had a long busy day yesterday.
We got my hitch raised up to eliminate the gap caused by the body lift. Paul also built up the receiver where it had been ground away from dragging on the rocks, then added a 3/8" slider onto the bottom.
We aslo made up one of the Idler arm adapters and got it installed on the Blazer.
Old Dec 20, 2012 | 07:53 AM
  #62
Jamaroon's Avatar
So I've been having some problems with my locker engaging, my best bet is it's the less than desirable connections Auburn supplied with the locker that weren't letting the locker get the power it requires to work properly.
This is what they provide and how I've been running it till now.
So obviously I needed a better way of doing the wiring, I noticed theres one blank spot in the dash fuse block. I figured this would be a good spot to put the locker fuse to make it look as factory as possible. I got another fuse block from the wrecker and scavanged the connections from it.
These are the two pieces I needed to wire in the locker. The one connector is for the locker power wire, and the one with the wire is to jump power from a power supply already in the fuse block to the blank spot I'm using for the locker.
Here is the connector installed on the locker wire
I pulled the fuse block down to get better access to it and remove the blue retaining clip
And installed the locker wire into the fuse block
I then removed the power supply for the front and rear wipers
And installed the jumper wire
Then re-installed it into the fuse block and the other end into the blank spot.
Re-installed the blue clip
And installed the fuse block back where it belongs. The spot marked "1" is the new connections, you can see them in the picture, and then install the fuse.
I also made a sticker for the fuse diagram.
I tested it out the best I can at the moment and seems to be working fine so far, will have to wait until the next outing to know for sure.
Attached Thumbnails Jamaroon's ZR2-img_0272.jpg   Jamaroon's ZR2-img_0231.jpg   Jamaroon's ZR2-img_0232.jpg   Jamaroon's ZR2-img_0239.jpg   Jamaroon's ZR2-img_0241.jpg
Jamaroon's ZR2-img_0228.jpg   Jamaroon's ZR2-img_0250.jpg   Jamaroon's ZR2-img_0252.jpg   Jamaroon's ZR2-img_0253.jpg   Jamaroon's ZR2-img_0255.jpg
Jamaroon's ZR2-img_0256.jpg   Jamaroon's ZR2-img_0258.jpg   Jamaroon's ZR2-img_0259.jpg   Jamaroon's ZR2-img_0260.jpg   Jamaroon's ZR2-img_0263.jpg
Old Dec 20, 2012 | 08:04 AM
  #63
rexmburns's Avatar
Super Moderator
Damn nice work man! I looks completly factory very clean!
Old Dec 20, 2012 | 11:57 AM
  #64
El_Beautor's Avatar
Props to you on installing it into the factory fuse block! I love making my wiring like it came from factory like that.
Old Dec 20, 2012 | 10:54 PM
  #65
Jamaroon's Avatar
Thanks guys.
Old Dec 21, 2012 | 10:17 AM
  #66
armykyle1's Avatar
armykyle1 is on a distinguished road
Man! You've done a lot of nice work to your rig!
It looks amazing man. I'm jealous!
Old Dec 22, 2012 | 03:57 PM
  #67
Jamaroon's Avatar
Thanks Kyle!
Old Jan 22, 2013 | 09:57 PM
  #68
timo98gmc's Avatar
timo98gmc is an unknown quantity at this point
One more? Does a 2 inch body lift mean i have to put a extension in my steering
Old Jan 22, 2013 | 10:10 PM
  #69
Jamaroon's Avatar
No steering is fine, shift linkage is fine everything you need comes in the kit
Old Jan 23, 2013 | 01:13 PM
  #70
timo98gmc's Avatar
Alright thank for the help
