KM346's SFA blazer (lots of pics)
Old Sep 3, 2012 | 11:49 AM
KM346's Avatar
KM346 will become famous soon enough
Default KM346's SFA blazer (lots of pics)
Hey everyone, had some time today so i thought it would share my SFA build over here. Some of you may recognize it...
Truck:
-2001 Blazer LS 4 door 4x4
72,000 miles
Front axle:
-High Pinion YJ Dana 30 w/4.10 gears
-ORD leaf spring SFA kit
-Rancho 44044's spring under axle
-Dana Spicer axles w/760X u joints
-TJ one piece passenger side axle
-F250 rear shocks
Steering:
-JB4x4 high steer arm
-YJ pitman on a ZQ8 box
-Moog YJ tie rods
-Custom drag link (91-95 ends + 87-90 adjusting sleeve)
-WJ front sway bar w/ YJ extended links
Rear Axle:
-Ford 8.8 w/4.10 gears
-Spring over axle
-New Ford axles / wheel bearings
-SN95 Mustang rear disc brake conversion
-Bastard pack w/ 1 ton leafs
-K1500 rear shocks w/ custom axle mounts
Driveline:
-1st gen s10 extended cab rear driveshaft w/ 2-1569 conversion Ujoint
-XJ front drive-shaft (needs to be shortened)
-1st gen electric shift t case w/ Jeep NP231 yoke
-ORD transmission cross member
Misc:
-TJ Rubicon wheels
-pro comp extended brake lines (front)
-K1500 Silverado center brake line (rear)
-custom modified y-pipe
-JTR 2.8 HD motor mounts
I'm sure I'm missing some details, just ask if you have any questions.
Old Sep 3, 2012 | 11:51 AM
KM346's Avatar
Old Sep 3, 2012 | 12:21 PM
KM346's Avatar
Old Sep 3, 2012 | 12:22 PM
KM346's Avatar
Old Sep 3, 2012 | 12:43 PM
xgiovannix12's Avatar
Trucks looking sharp Nice work !
Old Sep 3, 2012 | 12:50 PM
Jamaroon's Avatar
looks good, nicely done!
Old Sep 3, 2012 | 04:26 PM
jbw23's Avatar
jbw23 is on a distinguished road
Good looking blazer! Those rims give it a nice look!
Old Sep 3, 2012 | 04:58 PM
Brian_D's Avatar
Clean
Old Sep 3, 2012 | 09:53 PM
KM346's Avatar
Thanks everyone!
Old Sep 14, 2012 | 07:22 PM
KM346's Avatar
Bought a Trac-lock carrier off craigslist the other day for the 8.8. Ideally id like to have a locker back there... but this will be way more street friendly, and i got a good deal. I plan on rebuilding it with extra clutches so hopefully its nice and tight.
