Lifting 2" Progress journal
Old Feb 11, 2010 | 06:36 AM
  #21
04CVLXsport's Avatar
04CVLXsport is on a distinguished road
Guy on ebay called Skip White use sell a new metal body distributor for a really good price. Picked one up for my whites ZR2 after the tab broke and I wasn't gonna shell out 200+ bucks for another plastic POS. Don't see em listed on his ebay store anymore, just the 5.0 and 5.7's but I am sure if you emailed em they could get it. It was a nice piece click on this user name.. whiteperformance1
Old Feb 11, 2010 | 07:08 AM
  #22
NVANZEE's Avatar
Originally Posted by Dbam31
yah i wont go higher than a 1.5"
I just wanted a bit more higher profile, and enough to get my 30's on it.
You know for the record, how would I solve the joint wear out problem? And please don't a BL...
Like if I wanted to do a 4" or 6" (which I might do in the future). How would these problems be solved? Or would they be the same?
I also didn't understand the new keys...are they different from the stock? Thats the only thing I didn't understand why it came with the kit?
With the 6in lifts the front differential is dropped down so your cvs are still withing factory specs.
yah, too much work for me, high school then college SOON.
haha, thats why i just got the 2" kit.
(btw, so ur saying I could just pass installing the keys? Because I really dont want to take out the old ones, to much work)
You might be able to skip the keys depending on how much your tbars are sagging. If your tbars are sagging you might not be able to get much lift out of them. I was only able to get .75in out of my passenger side.
Old Feb 11, 2010 | 06:18 PM
  #23
Dbam31's Avatar
Dbam31 is on a distinguished road
i don't know how to check "sagging t-bars"? Could you explain that?
and I will put the keys in.
I bought the pos distributor from a salvage yard, for $70, looks good.
BTW
new rotor and distrib. cap solved my miss-fire and p300 code.
WOoooo!
so just gotta get that distributor in, my teacher is getting the part and we will put it in Tuesday. I wont be driving at all this weekend so that works out.
so crossing my fingers to do lift on Wednesday
instructions say I need a puller tool, and that I need to rent this.
Can I get this from an "Autozone"? and anyone have pics of what it looks like?
Thanks
Old Feb 12, 2010 | 11:45 PM
  #24
Boopappa's Avatar
Boopappa is an unknown quantity at this point
http://www.roughcountry.com/chevy_4wd_s10.html
Tool is at the bottom of this page, it also has boots for your shocks and a steering stabilizer if that is something you are interested in.
Old Feb 13, 2010 | 03:14 PM
  #25
tony991's Avatar
tony991 is on a distinguished road
Instead of buying an expensive torsion bar unloading tool, just buy a 6" C-clamp and grind off the movable foot so its just the ball. Works just as good and saves some green lol
Old Feb 14, 2010 | 01:47 PM
  #26
Do not use boots on your shocks, they trap dirt and poisture and kills the seals in your shocks.
these where on a truck less than a year. no road salt.
Old Feb 14, 2010 | 04:04 PM
  #27
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
boots are designed to keep moisture out. don't know about this one, wheres the boot, did you run it without the boot after they were installed. all the shocks i've put in without boots i usually wish i did later on down the road. can't ever say i've had a moisture issue with the ones that did have boots
Old Feb 14, 2010 | 11:13 PM
  #28
Dbam31's Avatar
hmm i will take the boots idea into consideration, but as of now the shocks are boot-less.
enjoying my vacation, no progress on the blazer to report of.
Old Feb 15, 2010 | 12:28 AM
  #29
DangerBlazer's Avatar
DangerBlazer is on a distinguished road
Cant wait for you to get the lift kit on man. Your gonna love it. Im in the progress of lifting my blazer as well. Im doing it by jacking the torsion bars and putting blocks in the rear. Does anyone know if I can still use factory shocks or if I need to get new ones? I was just going to buy some new Bilsteins from Autozone.
Old Feb 15, 2010 | 02:11 AM
  #30
OILCOUNTRY's Avatar
OILCOUNTRY is an unknown quantity at this point
Blocks won't lift your rear due to it being Axel over leaf. You can lift the rear with either an Add a Leaf of a simple set of shackles. And yes your factory shocks will be fine.
