Little Mouse - The 1994 - 4.3l TBI engine blueprint and tuning
Old May 6, 2024 | 10:31 AM
  #131
El_Beautor's Avatar
It's good to hear you're still working on it. It's been fun watching you build over the years, and I totally understand how life and other projects can overtake things.
Old Aug 12, 2024 | 09:25 PM
  #132
johnblaze's Avatar
johnblaze is on a distinguished road
Just an update. Too many things happened 2021 / 2022 / 2023.
At least the Blazer got a bit time on the road. Done a road trip to Italy in November of 2022. Over 1500 miles and going strong. Radiator has a small leak but leak-stop has worked so far. About time to finish that engine which is still sitting a the machine shop.
Camping with the roof tent near Salerno Italy
In the meantime the Blazer got it's own roof-tent. Been camping with it throughout 2023. Now sitting in the garage, I'm no longer taking it out into snow streets full of salt.
Looks like you've been putting your Blazer to good use, @error_401! That Italian road trip sounds epic! Love the setup with the roof tent, camping near Salerno must have been incredible.
Planning an Italian trip myself next year! Nothing set in stone yet, but Florence has been on my radar ever since I read this great article https://gowithguide.com/blog/tourism...ate-guide-5219. Apparently, you can walk the whole city in 30 minutes, perfect for someone who loves to explore on foot like me! Hoping to avoid the crowds by aiming for a September visit. Speaking of exploring, any other places in Italy you recommend besides Florence?
Old Oct 18, 2024 | 04:55 AM
  #133
Next small step, verify the timing.
short block.
Unwrapping and putting on a stand. I have to verif, the timing.
Degree wheel and stop fixed.
On the stand. And now "lunch"
Finally, camshaft timing is confirmed. I can continue. Next to the cylinder heads.
NOPE, no luck
Comp Cams grinds 4° advance into the camshaft, so the intake C/L is at 104° isof 108°.
"crap" - machining again .
Cutting oblong holes for the fixation bolts. Now the hole for the excentric keys.
The boss will take care of that tonight.
Old Oct 22, 2024 | 04:28 AM
  #134
Default retarding a cam
Retarding the cam centerline vs. the crankshaft with a gear drive which is not meant to be adjustable made us fumble some more.
After cutting the holes into oblong radius holes and opening up the cam center pin hole to accept the COMP CAMS degree bushings i csn proceed.
picture of the assembled valve chain on the block.
Old Jan 27, 2025 | 05:25 AM
  #135
Default Cylinder heads - valve spring shims
The cylinder heads need shims to get the right seat pressure for the valvetrain combo.
The only measurement that is determining this is the manufacturers 1.800".
To figure out the shim thickness first i have to measure the height below the retainer. This to be done with a barrel micrometer.
Barrel micrometer
Barrel micrometer
Now simply use the valve, retainer clips and measure...
there you go, now checking until the tool is finger tight.
Now i can calculate the shim height.
which i can average to 6.25 mm or .245"
Old Jan 27, 2025 | 05:39 AM
  #136
Default and clearance for the shims
I will need the shims to be wider and have a shoulder to center the springs on their OD.
but i'm limited because we need to be able to torque the heads and the nut has to enter between the shims. Smallest is 3mm (.12")
so, make sure there is enough clearance on every head-bolt
scale is metric.
scale is metric.
And it turns out that the asymmetric CHEVY heads pose a problem, so maybe i have to resort to another shimming method.
Maybe i have to guide the springs on the ID.
And now taking all measurements on the guides and spring seats and then to the drawing board.
Old May 27, 2026 | 06:42 AM
  #137
J-G's Avatar
J-G
J-G is on a distinguished road
Hello,
thank you to share your work on this car! Nice work, lot of things to learn.
I'm planning a similar project for my car. I've found your thread looking for balance information on this engine with a balance shaft as I was thinking in lightening the crankshaft, & install hypereutectic aluminum alloy lighter pistons. I think I will end up making the dynamic calculations to see how to adjust the balance shaft weight and weight distribution.
Another thing: I was thinking in installing stock rockers with roller bearing (like in LU3 07-14 engines, see picture) to have a bit more efficient top end but still simple and reliable. I'm not sure that roller/needle bearing tips are a good idea regarding the low pressure oiling system and the small oscillation conditions. My engine won't rev more than stock, and I would like to have service intervals as long as for a stock car at least. Do you have feedbacks on the reliability of your kind of roller for street use? Maybe it is necessary to used oil with special EP additives? I don't know if the roller on the tip has a needle bearing or just plain bearing (or steel on steel)?
man0steel
Engine & Internal
Apr 28, 2019 12:59 PM
Jimmy_Blazer
Jan 11, 2015 02:07 PM
error_401
Headers, Intake, & Exhaust
Feb 28, 2013 10:04 AM
fourwheeler_69
Oct 27, 2009 06:59 AM
95blazer4wd
Sep 18, 2008 10:38 PM
