Making a 91 vert S-10
Old Feb 17, 2009 | 12:25 AM
RolingKCBlazer's Avatar
RolingKCBlazer is an unknown quantity at this point
Default Making a 91 vert S-10
Me and a buddy are going to take his S-10 and turn it into an older style body kinda.... We are going to make it so the top can come off just like a K-5 blazer our plans are to cut were i marked on the photo on both sides and the top. re run wires for the rear interior light so it is still functional, then trim it down a little more and bend it a 1/2 inch over to the inside an place weather stripping on the top so when re sealed it dose not leak or let air in. the only thing we aint sure on is what to use to bolt it back through with but that'll come when time is here
Lemme know what ya'll think
we're gunna start to attack the project this weekend by cutting off the top.
Old Mar 8, 2009 | 09:55 PM
jlboots's Avatar
jlboots is an unknown quantity at this point
that sound like it woud work
Old Mar 9, 2009 | 08:01 AM
You have to be careful not to weaken the roof in that area. I would leave as little frame around the window as you can on the portion you are going to remove. Then weld it all shut. You may have to reinforce the roof area on both pieces.
Drop the headliner down and have a look what is under there. If you can cut right in the middle of a support beam, then you will have something to weld to for the caps as well as something that you can put a seal on.
Old Mar 9, 2009 | 06:37 PM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
neat idea
Old Mar 10, 2009 | 12:20 AM
cr8390's Avatar
cr8390 is an unknown quantity at this point
nice idea
Old Mar 17, 2009 | 01:37 AM
The idea has gone belly up someone blew up his Blazer after a fight at the bar....... and im selling my blaze because it still wont start
Old Mar 17, 2009 | 05:17 AM
bandidolenny's Avatar
Me and a friend did the same thing to a Suburban about 10 years ago. Although we were going to use a full size 76 - 91 Blazer top as a replacment. We ended up with a deer lease convertable and never did put a top on it.
musclecar70sfan
Dec 16, 2009 07:39 PM
BLK85
Jun 7, 2007 01:37 PM
BobTheBlazer
Feb 18, 2007 04:41 AM
2001blazer
Mar 29, 2006 01:51 AM
