My small 96 Blazer build
Old Oct 28, 2013 | 01:47 PM
  #731
Vader's Avatar
Vader is on a distinguished road
Originally Posted by Thogert
Hahaha, puny mortals. I'm running 1900 CA in one of my batteries.
Jesus, did you steal that from a Tractor or something??
Old Oct 28, 2013 | 08:00 PM
  #732
rexmburns's Avatar
Super Moderator
Originally Posted by bryanbc
What fuse box are you going with?
I'm not sure what fuse box I will use yet. Probably something with 8-10 fuses so I can add additional accessories as needed in the future. Heck I may go and pull one from a random car at the yard who knows lol!
I did add some cheap top post mounts with studs on them today and wired up the winch along with transferring all of my other wires to the top post accept the factory starter and ground wires. Went out in the woods and did a full pull with the winch just to set the line and everything worked perfectly. I had a large drop in volts which is I be expected but no drop in engine rpm while doing a constant 90ft or so pull so I think all is well with the setup. Now I just need to find a way to get stuck or better yet get someone else stuck so I have an excuse to use it!!
Old Oct 28, 2013 | 09:54 PM
  #733
WHOSBAD's Avatar
WHOSBAD is on a distinguished road
Sounds good Rex. Quick update on mine, one side is done...
and put on the winter wheels and tires,
Attached Thumbnails My small 96 Blazer build-ll4h.jpg   My small 96 Blazer build-15q6.jpg
Old Oct 30, 2013 | 03:02 PM
  #734
rexmburns's Avatar
Super Moderator
That looks good how you finished it up and blended it in!
Old Oct 30, 2013 | 03:09 PM
  #735
rexmburns's Avatar
Super Moderator
Got the sliders bolted on! I still need to get a longer drill bit to drill all of the top holes but with just the bottom bolts in they are incredibly strong with only half the bolts in.
My jack ran out of height!
And just because I can
Attached Thumbnails My small 96 Blazer build-737d9d72-c466-4b7c-82e8-6ea3e25851dd-1856-00000134a27ba415_zpsee1a0198.jpg   My small 96 Blazer build-649f8878-bed3-4a8a-a577-ecde86b92689-1856-000001348eae7734_zpse58b36f8.jpg   My small 96 Blazer build-a84017dc-f089-4c3d-b28c-1fb7f2439bfa-1856-00000134ae9ded2e_zpscbeb93cd.jpg   My small 96 Blazer build-a714c5f3-7b88-45fe-bf60-6adc716fd8fc-1856-0000013487ecfe19_zps027c0c73.jpg   My small 96 Blazer build-a559209a-cc87-487e-9569-e743264b5987-1856-00000134bb8573df_zpsdd61a290.jpg
My small 96 Blazer build-39e25679-e515-44c6-925f-2085b0bc898c-1856-00000134c1c7a36f_zps8e65d7fb.jpg
Old Oct 30, 2013 | 05:08 PM
  #736
swells87's Avatar
swells87 is on a distinguished road
Looks awesome, hopefully I can make some when I build my new front bumper over my thanks giving vacation (taking a week off of work). Any movement out of them when you jack up the truck off of them?
Old Oct 30, 2013 | 05:16 PM
  #737
rexmburns's Avatar
Super Moderator
Time is the hard part! I could knock a set out in a day if I had no interruptions and everything I needed there already. I couldn't see any movement at all even without the block of on the jack and only having 6 of the 12 bolts installed.
Old Oct 30, 2013 | 05:21 PM
  #738
warthogdriver's Avatar
looks good man...nicely done.
Old Oct 30, 2013 | 05:56 PM
  #739
rexmburns's Avatar
Super Moderator
Thank you sir!
Old Oct 30, 2013 | 08:48 PM
  #740
WHOSBAD's Avatar
Thx, the bottom edge is still all steel so they should work like your sliders but not as aggressive looking.
