N3ROST4R's 95 s10 blazer 4x4
Old Feb 28, 2012 | 11:44 AM
  #21
N3ROST4R's Avatar
N3ROST4R is on a distinguished road
Ya I thought about those but no idea how to really mount them. Your lucky those flat panels make it alot easier to mount stuff.
Old Feb 28, 2012 | 11:30 PM
  #22
cochran07's Avatar
cochran07 is an unknown quantity at this point
Build some "clamp" brackets of some type
Old Feb 29, 2012 | 12:46 AM
  #23
N3ROST4R's Avatar
ya have to make a run to the hardware store and look around. I'll come up with something. l
Maybe even a flat piece on the inside of the rack with a hole then a hole in the shovel then throw a bolt throw it with a wingnut on the end...
Old Feb 29, 2012 | 10:38 PM
  #24
cochran07's Avatar
Yeah or take you some thin plate steel and cut you out some mounts and weld up there. That will be the most secure way. I dont really know how to describe how mine are mounted but the guy that had the rack before me (it was a free score from a buddy of mine) basically has a tool that drills a hole and installs a nut in the actual frame itself so all my mounts were already there. Ill try to post up some pics tomorrow so you can understand it a little better cause I know that doesnt make a whole lot of sense.
Old Feb 29, 2012 | 10:41 PM
  #25
N3ROST4R's Avatar
I think I get what your saying. Just a bolt through the frame of the rack? That might not be a bad idea.
Old Feb 29, 2012 | 11:13 PM
  #26
cochran07's Avatar
No its almost like nuts have been welded inside the frame itself. Its called a nutsert if you want to google it..
Old Mar 8, 2012 | 12:56 PM
  #27
N3ROST4R's Avatar
I feel like banging my head against the wall. I just did a full tune up and new tranny fluid and replaced my fpr and I'm still only getting a little over 10mpg. I know running bigger tires and a roof rack will effect gas mileage but this seems a little ridiculous. It sucks I have alot of plans for the blazer but I'm not going to do anything until I know that its running right. It starts right up and idles great. I have no idea what it could be. Any suggestions?
Old Mar 8, 2012 | 01:01 PM
  #28
TheRandom1's Avatar
What gear ratio do you have?
I have 31s on my ZR2 with a 3.73 rear end and get 14-15MPG
Old Mar 8, 2012 | 02:29 PM
  #29
N3ROST4R's Avatar
I have 3.73 as well
Old Mar 8, 2012 | 02:44 PM
  #30
TheRandom1's Avatar
Hmmm. Well, removing the roof basket and stuff from the back would help a little, but I don't think they're the main cause. How hard to you drive it?
