Project Blazed
Old Apr 25, 2010 | 08:36 AM
  #211
sIcK dAiLy DrIvEr!'s Avatar
sIcK dAiLy DrIvEr! is on a distinguished road
the truck looks great but it would me better id it had a U of M sticker on it! lol! just kidding truck looks great!
Old Apr 25, 2010 | 12:25 PM
  #212
BlazerGuy2001's Avatar
ha you will never see a U of M sticker on my truck =p where abouts in michigan are you from?
Old Apr 25, 2010 | 07:54 PM
  #213
MTopper's Avatar
Honestly, i'll say this. i'm going to U of M dearborn right now (money isn't exactly flowing and my mom won't cosign a loan with me) and i still have an MSU plate on my blazer. MSU is in my blood guys
Old Apr 25, 2010 | 09:11 PM
  #214
well atleast your still an MSU fan...just dont get your blazer keyed cause you have that plate
Old Apr 25, 2010 | 10:22 PM
  #215
degaine_designs's Avatar
degaine_designs is on a distinguished road
That's one mighty fine looking Blazer.
Old Apr 25, 2010 | 10:37 PM
  #216
Thanks a ton
and everyone please excuse the body filler on the rear window trim pieces haha, i had some bondo mixed up and figured id put it on there to see how it would turn out once i was ready to take on that project...ill probably redo those next weekend!
Also, ill get some better pics of my blazer up here once the weather clears up enough to take them....this rain sucks!
Old Apr 26, 2010 | 05:50 AM
  #217
S10Blazerdude's Avatar
S10Blazerdude is on a distinguished road
Sick stuff you have done to your Blazer man! I never even thought about the bed liner on the lower part of a car. Good one. I am about to get my hands on a 92 s10 2door s10 blazer and I cant wait to start my stuff on it. Pretty much the same things as you.....the sound and all but no lift kit for me. But I am gonna put on a ground effects kit. Since I read your thread im thinking about putting that bed liner stuff on it. Just the bottom half.....the thing is red but it would look cool if the bottom was black. I will have to start my own thread like you and give updates and all.
I really like what you have done to your Blazer man......keep up the good work.
P.S. On my steros in the past.....I had one system that was 2500 watts and I had the problem with the alt not charging fast enough.....like you said the stock is about 100 amps for about 150 bucks.....i spent almost 180 bucks and got a 180 amp alt.....made all the differance in the world. I have only seen a few systems with caps in them.....but once they are used up, if you have your system still on it takes a long time before they are charged back up......the one system had like 5000 watts......then you would really need one....lol
Old Apr 26, 2010 | 07:20 AM
  #218
Thanks, and I would say go for it once you get your blazer! The reason I did it is because of the hundreds of chips I had along the rocker panels...they didn't look good and would eventually have turned into rust...also I had some rust along the rockers that I wanted to stop now before it got any worse. And now it looks great and should last for years to come! If you need some help if/when you do this to your blazer just message me and I'll walk you through it.
As for the sound system I think it is a problem other than the amp, I am only running an 800 watt rms system and I find the battery dead nearly every morning. There is a problem other than the stereo that I need to work out =\
Old Apr 26, 2010 | 08:37 AM
  #219
tofunater's Avatar
tofunater is on a distinguished road
Do you have your amp trigger wire in place? If you don't then your amp may be on all the time consistently draining your battery.
Old Apr 26, 2010 | 08:43 AM
  #220
By trigger wire do you mean remote wire? If so yes, I have it wired into the ignition, so it turns off with that, also to a switch if I want them off when my ignition is on, but I have the radio on almost all the time when driving... I replaced the cluster because the shop said that was the problem but it didn't help....$200 down the drain..
