Project Blazed
you are trying to go black or color match? if it's color match get the gm paint in a can. match by color code on your glove box sticker. if it's black duplicolor or krylon seems to do well. make sure you give it a once or twice over with a clear if you want it to hold up longer.
If it were me I'd leave your grille.
But that's just me. You have a color coded grille which suits your truck really well. The only reason I painted mine was because it was before the days of color coded grilles and it was a cheap faded grey plastic.
If you do decide to paint it though keep in mind it's plastic. Krylon is the best paint to use on plastic. I just used regular primer and regular paint though and it's help up fine so far. No nicks or dings that I'd found.
hmm thanks for the input i think i will just leave it the way it is right now. Does anyone know anything about shackles and a torsion bar crank? i've been wanting to get like a 2" lift to my truck and im thinking thats the way to go....what does it involve?
There is TONS of info on the forum about tbars and shackles. It's a very easy and cheap way to get up to 2" of lift. Do a search if you want more info then this...
Here is a great external link explaining shackles: http://www.jeeps-offroad.com/f57/sha...they-do-20993/
The tbars are literally just 2 bolts you crank to gain lift in the front. The shackles are pretty each too. Just a couple of bolts to remove and replace.
https://blazerforum.com/forum/showth...t=shackle+lift
Here is a good thread with pics about shackles.
Thanks for the links, i might do this but i gotta get my new sound system ordered, hooked up, and working first! and i gotta convince my dad to let me...parents....Anyway, i'm almost done with the tire rack, the paint is drying now and i will probably put it back on my truck later tonight, i will post the pictures when i'm done.
