Project: Bringing back Brutus
Old Mar 24, 2010 | 11:29 AM
K5corey's Avatar
K5corey is on a distinguished road
Default Project: Bringing back Brutus
I have a 1984 K5 blazer (that i call brutus) i bought from my cousin for 900 bucks. It had a blown engine but otherwise was in fairly good shape. i started looking for an engine but got laid off so it has sat in my garage for 9 months.
I now have gotten the engine pulled out and the block is done for. 2 pistons were blown apart with two others cracking, one of the connecting rods was bent 90 degrees. So its junked sitting in my garage for now.
I just bought a 400 small block for $350. it will be getting a new towing cam and lifters, double roller timing chain, rocker arms, rods and new gaskets. it also has 305 heads on it.
pics to be posted soon.
Old Mar 24, 2010 | 12:11 PM
Sounds like a pretty good deal.
Get yourself a set of the newer Vortec heads and an intake that will bolt up to them!
Old Mar 24, 2010 | 01:22 PM
abig84's Avatar
I've been running a 400 for about 5 years. Great engine
Old Mar 24, 2010 | 02:56 PM
1oldK5's Avatar
1oldK5 is on a distinguished road
400s are nice torque motors, buddy of mine has one in a '74 k10 (4x4 shortbed) with 8 lug axles swapped on. Nice strong motor..
Old Mar 25, 2010 | 09:38 PM
wlorton's Avatar
Man just saw this thread... looks like it could be beastly!
Old Mar 26, 2010 | 12:34 AM
old skool luvr's Avatar
that 400 is gonna be right @ home in that K5 of yours.
Old Mar 26, 2010 | 09:57 PM
K5corey's Avatar
Ok I have pics to post but I'm having trouble posting them. Gonna try again tomorrow... yesterday I started degreasing the engine bay so I can give it a new coat of paint and I also painted the battery tray but I didn't do anything today because it snowed (in Ohio).
I'm gonna tear down the 400 smallblock this weekend. I've been reading on the 400s and seen there is alot of talk about overheating if you switch heads or dont run high enough rpms does anyone know about overheating problems?
Old Mar 26, 2010 | 10:03 PM
400's definitely can have heat issues. It stems from the fact that the cylinder walls are siamesed. To give sufficient wall thickness around the cylinder bores, the walls connect between each set of pistons where other small blocks have water jackets that flow between the cylinder bores improving thermal transfer and reducing hot spots that can cause flash boiling of the coolant.
Old Apr 29, 2010 | 10:07 AM
K5corey's Avatar
Ok so I've been busy lately so I haven't added any updates.
I got the 400 stripped down and it's going to the machine shop to get cleaned up line bored and honed. I also am getting steam holes drilled into the heads since they are not 400 heads. Next stop is summit so I can drop some money lol. I'm having trouble uploading pics is there something I'm doing wrong?
Old Apr 29, 2010 | 10:33 PM
try using photobucket.
worked wonders for me (and many others on here).
hoebob69
Sep 4, 2014 08:57 PM
247monster
Apr 27, 2013 12:58 PM
Bob'sblazer
Oct 5, 2010 02:59 AM
ZigZaggle
Aug 5, 2010 02:19 AM
Biohazed
Mar 24, 2010 05:35 PM
