Project: It's about time.
#211
haha, i was gonna suggest buying a switch out a newer model. but im not sure if they would interchange.
#212
Hmm, I think that might be worth checking out next time I'm at the junkyard.
#213
I have a 96 parts blazer that I got the switch out to check. It had the small 3mm light in it. So I checked mine to see if it was the same and they look the same. But I didn't check to see if they would interchange. Maybe they are the same just changed the lights.
#214
Yeah it's possible that it is a 3mm neowedge. I haven't looked at it for almost a year now.
#215
wow ha my window switch stopped workin, so i took it out to change it and seen it had a changeable light. i was like that would be cool if i could find them in blue so i started doing some searching and came across your post about your lights. ha
#216
so i got to searching, the hvac, rear wiper controls, defrost, and the 4x4 switches are different in my 98. have you heard anything about the lights in those? or do they have the same lights in them as the older models?
#217
I haven't had a chance to look at those controls in a 98+ blazer. If I had access to one I could figure it all out (probably) But until I get a chance to screw around with one, you guys will be on your own.
#218
Ah. Alright man. I figured. Thanks thought.
#219
So I took a look at my window lock switch light today, and I believe you are right, it looks like a 3mm neowedge socket. The reason I didn't replace it is because there was no bulb there to begin with, so I didn't know what type of bulb it took until you said something.
#220
ha ordered you a light yet?
so i got some leds in today i ordered off ebay.
gonna see how they do, then i might order some more for the dash.
had to dremel out one of the metal reflectors because the light wasnt going in far enough to get a good connection.
