Project: Sadie
Old Feb 11, 2011 | 02:42 AM
  #211
MTopper's Avatar
good call on denali lights. i think they'd look good on your truck
Old Feb 11, 2011 | 07:47 AM
  #212
oktain's Avatar
Thanks, I'm pretty pumped to get my job back in April so I can order them and everything else lol.
I'll be honest, I can't wait to run HID's again, but I NEED a relay harness for them. I could easily make my own but I'm not sure where to get the necessary plugs for it.
Old Feb 11, 2011 | 10:17 PM
  #213
cbr995's Avatar
Relay harness? What exactly do you mean?
Old Feb 11, 2011 | 10:53 PM
  #214
old skool luvr's Avatar
i've heard that the newer Sierra/Silverado's need a realy harness for the HID swap.
guess he shoulda stuck with his plug-n-play Blazer, eh?
Old Feb 12, 2011 | 02:38 AM
  #215
MTopper's Avatar
honestly, any car can use a relay. it just "helps" with the hook up of the HID. it helps with the electrical draw. i hear this crap every day from my "boss" with his business
Old Feb 12, 2011 | 09:31 AM
  #216
oh, i know every install could benifit from using relays, it's just some require it to reduce the draw required.
i've also read about some installs warning of possible fire hazards if they're not used.
Old Feb 13, 2011 | 01:09 AM
  #217
MTopper's Avatar
yeah... i'm learning all the ins and outs of HIDs and window tinting now so i'm just going off basic learning and such. i'd probably benefit from it with the draw of my system.
lets see what happens
Old Feb 13, 2011 | 09:54 PM
  #218
oktain's Avatar
03+ Fullsize trucks NEED them. The inconsistent power draw at start up makes the PCM think there's something wrong and throws the truck into a "Reduced power mode", or a limp mode.
When this happens my truck sounds like it's running a lumpy cam but has the horsepower of a Prius.
I unplugged the low beam relay, restarted the truck and NO issue, I pulled the HID's out in June, and no issues since WHATSOEVER.
Did some research and the use of a relay to send (fused) power straight to the HID's is needed.
Old Apr 4, 2011 | 01:00 PM
  #219
zedartwo's Avatar
Could you maybe post up a thread about it. Like make a sticky about ANY HID install using relays. I'm still not quite familiar with Fullsizechevy.com. Its like meeting your GFs crazy family lol. I'm still recovering from that one lol.
Anyways, was it you that said you can use 2 sets of 9005 (or 9006. can't remember).
Old Apr 4, 2011 | 01:14 PM
  #220
oktain's Avatar
Problem is the 9005's which are high beam (you can use them) require some modification to the headlight housing. The "neck" of the bulb where it fits into the hole of the housing is also too small, you'd need a spacer to take up the extra room.
Here Brad: HID Relay Kit
How does it feel to be a noob on a forum again? lol... "Search next time "
