PROJECT solid axle swap/lift
Old Jan 13, 2010 | 07:06 PM
  #71
abig84's Avatar
Nope. The whole carrier would have to be swapped. Im not really sure if they are interchangable or not. 8.5 stuff should be the same but not sure. Are the ratios the same? Just swap axles if so
Old Jan 14, 2010 | 12:45 AM
  #72
xtreme821's Avatar
xtreme821 is an unknown quantity at this point
yeah gear ratios are the same but the 6 lug has blown gears. like beyond attempt to rebuild. well i will find out later today. ill keep you posted
Old Jan 14, 2010 | 03:11 PM
  #73
86Blazer327's Avatar
86Blazer327 is an unknown quantity at this point
It wouldnt be the spider gears , it would be the side gears. Anyway , like I said , your just gonna have to tear into it to find out. Not a whole lot of people even mess with 10 bolts, myself included, enough to even care to know if the axles will swap. If you were closer to AL I would give you 4 of them to get them out of my way. Junk imo cause they wont hold up to a 35" tire unless you baby it all the time
Old Jan 16, 2010 | 11:31 AM
  #74
xtreme821's Avatar
i meant side gears, my bad. so the spline on my 5 lug is actually larger than the six lug? doesnt make sense but it is what it is.. have side gears laying around in the parts rear, but will i be able to use the posi carrier with them or do i need to swap in the open one? ordered tires too, 16.5x8.25 pro comp rock crawlers, special order 4 weeks, enough time to finish her off hopefully.
Old Jan 16, 2010 | 11:49 AM
  #75
abig84's Avatar
I know little about swapping carriers. I run 10 bolts. I just buy a new axle if i break something
Old Jan 20, 2010 | 10:46 PM
  #76
xtreme821's Avatar
just solved all my problems. bought some adapters that go form 5 lug to 6 lug (ezaccessory.com), came out to 140 shipped. well worth the headache in my opinion. i can keep my posi rear now working on drag link tomorrow as well as filling up my rears and changing fenders. if theres time ill run fonr brake extensions but i doubt myself getting that motivated
Old Jan 21, 2010 | 11:06 AM
  #77
abig84's Avatar
theres a few places that make drag links. you just have to give them the measurements and what tie rods your using. also if you wanna make your own they sell the threaded ends for the tie rods y ou just have to weld them onto some dom tubing
Old Jan 21, 2010 | 05:04 PM
  #78
xtreme821's Avatar
i have tubing and one threaded end, just have to pick up one more. never got around to it today. i did put my posi unit back together and tore off my old fender. no more snorkel still waiting on rims and adapters, prob gonna buy a battery tomorrow too. getting closer!!
Old Jan 21, 2010 | 07:24 PM
  #79
blazeitupdrgonzo's Avatar
blazeitupdrgonzo is on a distinguished road
This is an awesome build, I cant wait to see the finished product.
Old Feb 1, 2010 | 10:32 AM
  #80
xtreme821's Avatar
rims come tomorrow. i promise pics then.
