Rough Country 2.5" Lift!!!!
Old Nov 18, 2011 | 10:43 AM
  #111
2001sls's Avatar
2001sls is on a distinguished road
did both over and over and no go
Old Nov 18, 2011 | 10:46 AM
  #112
TheRandom1's Avatar
Well then I'm out of ideas. Hopefully someone else can help.
  #113
Benedict1337's Avatar
use a saw zaw that is what I had to do get to most the the bolts off on my 4runner.... or if you have an impact gun, I impacted my torsion keys, I never have taken them off thou so I'm not exactly sure how to do that
Old Nov 18, 2011 | 11:51 AM
  #114
Mike98Blazer's Avatar
If you're going to use the new torsion keys that came with the kit then you should be able to cut them with a sawzall and grinder to get them off. Just be careful not to damage the bar itself. As far as getting the bar out of the lower control arm lots of patience and a bfh.
Old Nov 18, 2011 | 03:13 PM
  #115
2001sls's Avatar
the keys are kinda tight in the crossmember but i'd try anything at this point
Old Nov 18, 2011 | 05:32 PM
  #116
huntersblaze's Avatar
huntersblaze is on a distinguished road
2001sls, I had your same problem, I was pounding at them for hours, the solution is heat, after you get keys nice and hot the torsion bars practically slide out themselves
Old Nov 20, 2011 | 01:21 AM
  #117
PaulO2288's Avatar
PaulO2288 is on a distinguished road
Can anyone thats done this lift post a pic of how their front diff sits with the drop bracket or give an idea of how much its actually lowered it? Also how are the axles sitting with the lift because after a normal tbar crank im tired of going through axle boots and hubs from the axles being at too much of an angle and extremely curious to see if the front drop helps!
Old Nov 21, 2011 | 12:53 PM
  #118
El Diablo793's Avatar
El Diablo793 is on a distinguished road
Just for reference, mine, with all of the new parts on it and the new kit rides stiff. The diff. Drop really doesn't drop it all that much. My front from hub sits at 21"- back at 22". I'm curious as to whether I'm topping, or bottoming something out because over some bumps at around 45mph it feels like the front tires lift off of the ground...maybe because I should get a steering stabilizer? I don't know. You will probably experience it too in time. Anyways, I took it on a 45 mile trip this weekend. It drove pretty dang well, just the bumps and I constantly check my cv's. I'm way paranoid now.
Old Nov 21, 2011 | 06:37 PM
  #119
rhino420's Avatar
rhino420 is on a distinguished road
Hey Guys, so got a question Im looking to order this rough country kit but Im trying to go for a Pre-runner look with a higher front end then back end as of right now my 02 blazer 2dr 4x4 non zr2 is sitting stink bug and I hate it . Do you guys know if ill be able to achieve this look with the rough country kit? Im a noob to all these so please be kind.
Old Nov 21, 2011 | 07:04 PM
  #120
you should be able to achieve that look by not replacing the rear shackles with the lifted ones
