SAS transfer case issue
Old Oct 8, 2009 | 03:28 PM
xtreme821's Avatar
xtreme821 is an unknown quantity at this point
Default SAS transfer case issue
okay to make this short....
any way i can get a transfer case to bolt to my transmission to make the front driveshaft output on the passenger side of the truck ?
Old Oct 8, 2009 | 04:07 PM
You will need to get a different transfer case. You cannot flip your current transfer case as the oiling will be all wrong. Since there was never an s-series with a passenger side drop, you will have to try for one of the NP208 or NP241 transfer cases from the fullsize trucks with a passenger side drop. This would be in the K5 and Suburban up to 1991.
Old Oct 8, 2009 | 06:47 PM
abig84's Avatar
yep. i got a np208 on my 93. just snag the 700r4/np208 adapter. it bolts right on.
just a heads up your front out put shaft is gonna be right in the middle of your crossmember so your gonna have to replace or modify yours so the driveshaft will clear it
Old Oct 9, 2009 | 11:47 AM
xtreme821's Avatar
my blazer now has the push button 4x4 system, what would happen with that ? would i need to convert my truck to the manual shift ?
Old Oct 9, 2009 | 02:25 PM
abig84's Avatar
Yea you'll need the floor shifter too or find one that works with that case. My 93 was a push button also I just tied the wires up out of the way under neith.
The bad thing about the np208 shifter is its floor mounted. So it'll work but it kinda goes into the passenger area. But u can probably raise it up some
Old Oct 9, 2009 | 11:41 PM
abig84's Avatar
heres a picture of the output shaft running into the crossmember
and my ghetto fix
heres the floor shifter in my truck... its angled into the passenger area which kinda sucks cause you have to make sure no one kicks it out of gear.. but if ya spent time you could probably make some kinda bracket so it it stood straight up.
Old Oct 10, 2009 | 06:31 AM
xtreme821's Avatar
wow thanks for that. guess its time to cut out a hole in my floor, haha. what exactly did you do to that crossmember, i cant tell from the picture
Old Oct 10, 2009 | 09:56 AM
abig84's Avatar
i basically just cut out a 6inch section. i originally welded up part of a trailer hitch under there just for the build process and came back later and fixed it. i was gonna do a custom crossmember but got lazy.
as you can see it hung down way to low. so i just cut that part out and bolted in some C channel its place.
im sure there is a easier more simpler way to do a drop on the crossmember then my set up
Old Oct 11, 2009 | 07:21 PM
xtreme821's Avatar
that skid plate set up is nice. ill definitely work in something like that.. ill be starting the swap this coming week, there will be a new build thread starting up
thanks to all who helped, and all who will help
Old Oct 12, 2009 | 12:32 AM
abig84's Avatar
Yea I recommend having a skid plate. Mine is scratched up like crazy from hitting stuff. Saved my transfercase for sure
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
okiedoak20
18
Feb 26, 2012 10:36 PM
crap98blazer
Mar 8, 2009 08:06 PM
JOHNBOUY
Oct 23, 2008 05:25 AM
