-   Builds (https://blazerforum.com/forum/builds-48/)
-   -   sfa (https://blazerforum.com/forum/builds-48/sfa-28357/)
fst450 Mar 7, 2009 01:06 PM
3 Attachment(s)
finally decided to cut er up
2 inch body lift originally then did the swap. aprox 12 more inches with 35 swamper boggers. also did a 5 speed tranny swap. tired of changing the crappy auto tansmissions.
Taymacjack Mar 7, 2009 07:54 PM
You should do a "how to" for a SAS. Tell us more.
lilskaterpunk Mar 7, 2009 08:18 PM
Thats bada$$ looking. Awesome job!
Blazer_boy Mar 7, 2009 08:33 PM
Nice Ride, Just curios, as to the tranny swap, how difficult was it, im having the same problem with my '91 Blazer
willjones Mar 7, 2009 08:42 PM
That thing is bad!
swartlkk Mar 8, 2009 09:09 AM
Yes! Nicely done!!
fst450 Mar 8, 2009 11:21 AM
The tranny swap was very easy. I gatherd all the parts needed so i was prepared. The most difficult thing to install for me was the clutch and brake pedal. Driling through the firewall and dealing with wires in the way. the fire wall has dimples in it as to were the holes need to be drilled for the slave cyl.
I used a tranny out of a zr2 blazer my transfer case bolted right up and would have been able to use the stock size driveshaft it it was not for the solid axle swap.
Other than that a hole in the floor for the shifter and some other odds and ends it went very well we a buddy and i did it in 2.5 hours with a hoist.
Blazer_boy Mar 8, 2009 11:58 AM
Hmm, well I guess I shall start gathering parts then, im on my 3rd Tranny and its on its last limbs as well....the automatic's just dont stand up to the abuse off road.
Thanks for the help!
fst450 Mar 8, 2009 12:14 PM
5 speed is the way to go. Good luck!
Taymacjack Mar 10, 2009 01:44 AM
what did you get the axles from?
