Tank
Tank
So this is the start of a new project. What I started with, stock.
What I have done...
AirRaid Cold Air Intake
AirRaid throttle body spacer
Cherry Bomb Hi Flow Cat
Delta 40 Flowmaster Muffler
Descreened MAF
Removed Throttle Blade Diffuser
31" Goodyear Wrangler A/T
Chopped 36" off exhaust
Gabriel Max Control Shocks
What I have planned.
Accel Coil and rotor
ECM Tune
3" lift
P&P heads
bigger valves
hedman headers
body work
bigger flares
SFA swap
and of course lobby congress to have emissions removed from my vehicle.
More pics to follow as i have already done more work.
What I have done...
Descreened MAF
ECM Tune
3" lift
P&P heads
bigger valves
hedman headers
body work
bigger flares
SFA swap
Good build so far! I wanna see more pics of that hood.
When I got the truck it had these scoops on here. They were for decoration only, not cool. So I cut through the fake screens and started cutting holes through the hood. The plan being to hook the intake to them. I am still fabricating new screens to put in front and still working on the air box to connect to the hood.
with new shocks and undercoating along the side. I still need to undercoat the fender flares and both bumpers. Also putting a 2 inch lift on next weekend.
I have some of the interior out right now for painting. Will post when done. Also pulled the tow hooks off to give them a coat of fire engine red.
cool project so far man, how did you descreen the maf?
Needle nose pliers on the MAF. Rust-Oleum ford red ceramic engine enamel. I used the engine paint because it dosent chip off. Also for plastic you might wanna use a filler primer to smooth out the dimples in the plastic.
okay thank you
So of course it rained about an hour and a half after applying another coat of undercoating to the trim and sides, why do weather men get paid again? Anyways have some more pics up this afternoon.
