A thoroughly British Blazer Build
Old Jan 22, 2014 | 11:18 AM
Lippyp's Avatar
Lippyp is on a distinguished road
Yeah Big 3 is on my list, I know a load of car audio fanatics so they'll be able to help me out there.
Old Jan 22, 2014 | 06:18 PM
Dobe Rottie Gang's Avatar
Dobe Rottie Gang is on a distinguished road
Its only 3 cables you have to change.
Ground from battery.
Ground from engine.
Live from battery to the alternator.
Do it yourself and save some cash.
Old Jan 22, 2014 | 11:12 PM
Twip's Avatar
i would agree, save the money and do it yourself. unless you are already planning to, in that case, i will bugger off.
Old Jan 23, 2014 | 03:12 AM
Lippyp's Avatar
Yeah, will be doing it myself. What gauge cable would you guys recommend? The good thing is it had a new alternator last year and the battery is only a couple of years old so the charging system is in decent condition.
Old Jan 23, 2014 | 07:23 AM
I did my one's in 10mm.
I just got a metre length of 10mm twin and earth and stripped out the copper earth and used the Pos and neg. The whole job cost me £2.00 for the 6 connectors.
Old Jan 23, 2014 | 11:07 AM
Tajohns34's Avatar
I did my big 3 this summer. I would recommend getting a DR44G or an AD244 alternator upgrade. That was a huge help, I went from around 11.5 volts with my e-fans on to about 14 with them on.
Old Feb 9, 2014 | 02:04 AM
Lippyp's Avatar
I grabbed a couple of hours out in the garage yesterday and made a start on my light bar. Its made out of some angle and some box section steel and designed to bolt up to the factory roof rails using some captive nuts I will make. (two per side.) makes it totally reversible and fairly low profile. Got everything cut out and drilled and prepped to weld up. Just need to make a tab to weld on the back of it so i can put a CB antenna up there too and then weld it together. Then a coat of paint and sort the electrics out.
I need to find someone local to me with a tubing bender so I can make something for the front bumper for my pair of big Hellas.
Old Feb 11, 2014 | 08:43 AM
Lippyp's Avatar
This is how the light bar lookks at the minute, all ready to weld up.
Attached Thumbnails A thoroughly British Blazer Build-lightbar1_zps861c7f70.jpg
Old Feb 11, 2014 | 10:34 AM
Looking good but how are you going to fix it to the roof rack so that it doesn't lift in the wind?
Old Feb 12, 2014 | 03:13 AM
Lippyp's Avatar
I'm going to make some captive nuts by welding them to a steel plate the right size to slip into the roof rail, two 8mm bolts per side should stop the bar twisting or lifting. Does mean I need to take the roof rails apart at one end to get the nuts in but it also means its totally reversible should I sell it. Bolts will be loctited in. The lights are also pretty small so its not like whacking four dinner plate sized spots up there so wind resistance will be fairly low.
The lights are Hella FF75's like the ones on this nissan which was my inspiration.
Attached Thumbnails A thoroughly British Blazer Build-3821131015_e9fe256af8_b.jpg   A thoroughly British Blazer Build-3821149137_30ba22c0c7_o.jpg
