Trailmaster Install
Deleted
Last edited by b1heqh54; Jul 29, 2011 at 06:53 PM. Reason: *Consecutive Posts* - Please use the edit feature to add more information to your post or use free online photo hosts to post more than 5 images.
Can't wait to see the start of you install. I do not suggest you install your rims because they are only 7" wide and will rub on your sway bar. Also some tire manufactures require wheels to be 8" or wider. You might wanna check with them as to what they reccomend. Also, did you get a power programmer so you can recalibrate your speedometer? It will be off when you install those larger tires.
Deleted
Last edited by b1heqh54; Jul 29, 2011 at 06:54 PM. Reason: *Consecutive Posts* - Please use the edit feature to add more information to your post or use free online photo hosts to post more than 5 images.
