Trailmaster Install
Old Aug 9, 2010 | 05:10 PM
b1heqh54's Avatar
b1heqh54 is on a distinguished road
Deleted
Attached Thumbnails Trailmaster Install-p4300003.jpg   Trailmaster Install-p4300005.jpg   Trailmaster Install-p4300007.jpg   Trailmaster Install-p4300001.jpg   Trailmaster Install-p4300002.jpg
Old Aug 10, 2010 | 07:33 AM
b1heqh54's Avatar
Deleted
Attached Thumbnails Trailmaster Install-p4300001.jpg   Trailmaster Install-p4300002.jpg   Trailmaster Install-p4300001.jpg
File Type: txt
File Type: txt
File Type: txt
Last edited by b1heqh54; Jul 29, 2011 at 06:53 PM. Reason: *Consecutive Posts* - Please use the edit feature to add more information to your post or use free online photo hosts to post more than 5 images.
Old Aug 10, 2010 | 09:19 AM
nj4x4blaze's Avatar
Can't wait to see the start of you install. I do not suggest you install your rims because they are only 7" wide and will rub on your sway bar. Also some tire manufactures require wheels to be 8" or wider. You might wanna check with them as to what they reccomend. Also, did you get a power programmer so you can recalibrate your speedometer? It will be off when you install those larger tires.
Old Aug 10, 2010 | 09:37 AM
b1heqh54's Avatar
Deleted
Old Aug 10, 2010 | 10:07 AM
nj4x4blaze's Avatar
Spacers are scary but those z28 wheels are good. Hopefully UPS hurrys up and brings you your kit today.
Old Aug 10, 2010 | 10:33 AM
b1heqh54's Avatar
Deleted
Old Aug 10, 2010 | 11:03 AM
Benedict1337's Avatar
you could always look at the older z28 wheels that are only 15 inch. I think they look pretty good on a lifted truck
Old Aug 10, 2010 | 11:18 AM
b1heqh54's Avatar
Deleted
Attached Thumbnails Trailmaster Install-p4300001.jpg   Trailmaster Install-p4300001.jpg   Trailmaster Install-p4300002.jpg   Trailmaster Install-p4300003.jpg   Trailmaster Install-p4300004.jpg
Trailmaster Install-p4300005.jpg   Trailmaster Install-p4300001.jpg   Trailmaster Install-p4300002.jpg   Trailmaster Install-p4300003.jpg   Trailmaster Install-p4300004.jpg
Last edited by b1heqh54; Jul 29, 2011 at 06:54 PM. Reason: *Consecutive Posts* - Please use the edit feature to add more information to your post or use free online photo hosts to post more than 5 images.
Old Aug 10, 2010 | 02:35 PM
looking forward to see how it looks. I've been swaying towards getting a trailmaster over a superlift
Old Aug 10, 2010 | 02:59 PM
nj4x4blaze's Avatar
Trailmaster isn't bad. At least the parts are labeled.
