What should i do to my 1988 S-10?
If you have torsion bars on your truck like i have on mine which i think it came stock on most of these trucks you can simply do your two inch lift on that but if you dont want to go that way i would look into a suspension lift body lifts are cheap but you have to replace them after a few years because the blocks rot away
When is the last time you heard of someone having to replace the factory blocks? A body lift uses the same material as what the factory uses in their blocks, just longer.
NOW, if you are using hockey pucks on a body lift, well, you should just be put out of commission, IMHO.
Yeah i am pretty sure i have a T-Bar, i just dont know how to crank it and i havnt had much luck looking for explanations on it.
Currently i am working on getting my ne wheel well trim mounted on, along with some other stuff. pics should be up sometime today. hopefully.
sting_da_man
Mar 13, 2006 12:48 PM
