White knight!
Old May 16, 2020 | 05:23 AM
  #61
03jawja's Avatar
Finally decided to go to top terminals. I got a deka second line agm 34 group for $62 from deka depot here!
Adding a run off 6 gauge from main fuse to fuse box and from main fuse to battery. Interior lights are little brighter.
New and old
Old May 16, 2020 | 09:03 AM
  #62
Looking good. How are your home mad hood vents working out?
Old May 16, 2020 | 11:21 AM
  #63
03jawja's Avatar
Better than i thought..i will definitely cut out the holes bigger soon. After about 30 mins , the hood is barely warm to the touch, but the vents hot! I wsnt to add one in between the window fluid sprayers. I will be doing alot for cooiling over the next 2 months
Old Jul 5, 2020 | 08:01 AM
  #64
03jawja's Avatar
Picked these up for 10 bucks as makeshift traction aids...used them with anchor pins. They work decent, might add snow studs to them later
Gave it a good wax with griots 3 in 1 ceramic. It came out really good.
Old Jul 6, 2020 | 08:49 AM
  #65
03jawja's Avatar
Went to tractor supply and got some u bolts to mount them, and i used some mini straps from work for shovel and a old gun lock.
Old Sep 13, 2020 | 07:15 PM
  #66
03jawja's Avatar
Got bored and wanted some extra power oprions for my drills and work equipment. I set a budget for myself which was 40 bucks. A yard sale or 2, scraps from work....and magic!!
The white and green 12 awg and tied into my secondary fuse panel.
2 sealed agm fire alarm batteries from work
Old Dec 24, 2020 | 05:34 PM
  #67
03jawja's Avatar
Did some repairs the last 2 weeks. Front shocks, front brake pads, rear pads and rotors, fuel pump, copper distributor cap and rotor, cat delete, and a front end grease
fuel tank was a b**** alone. Lesson learned drain gas tank!!
Old Jan 10, 2021 | 05:08 PM
  #68
03jawja's Avatar
Finally did the throttle.body mod, only took 20 mins. I enjoy the extra pep off the line. Wasnt too touchy like some people described, it was just right. Also dropped my bland filter with a low budget performance filter (UPGR 8). Its running great
Old Jan 10, 2021 | 05:10 PM
  #69
03jawja's Avatar
Here's some sound vids of the cat delete
Old Jan 20, 2021 | 02:26 PM
  #70
03jawja's Avatar
Added some new grille lights. Eagle eye leds kept going out. This time i used trailer amber leds and rock lights. I wire them on a relay as well. Im also starting on my second battery box as well. A 51r fits well in jack location.
51 r agm reconditioned
pj5454302
Mar 6, 2015 07:08 AM
Thogert
Nov 1, 2013 12:19 PM
killallblue
Jan 27, 2013 05:31 PM
Logan
May 7, 2011 07:20 PM
69chevelle
Dec 11, 2010 02:29 AM
