How To: Lowering in Photoshop
Old Sep 12, 2010 | 07:04 PM
DarkPhantom27's Avatar
DarkPhantom27 is on a distinguished road
Default How To: Lowering in Photoshop
This tutorial is to teach you how to take a normal car and slam it in reason to the ground. This is a simple tutorial that anyone can do. I will be using the same Blazer I used in the first tutorial ( Wheel Transfer in Photoshop).
First things first. Open Photoshop and open the vehicle you will be using. Any angle can be used for lowering. I will be using the 3/4 view once again.
Step 1: Lassoing
First you will want to grab the Polygonal Lasso. Start at the far right of your picture at the back bumper just above the ground or just below the ground where the background meets. You want to follow the vehicle going around the wheel arches above the wheels them self (above the wheel wells). Now go all the way along to the front of the vehicle to the front bumper/ fender to the ground again ( either above or below the background). Follow the outside edge of the photo to the top, go along the top of the photo meeting the far right and go along that side down to where you first started then across the ground until you complete the lasso. Just like the picture below.
Step 2: Lowering
Now that the picture has a big flashing line going around it we can move it down but first make sure the background color is black. You do not need to copy the layer, doing it this way makes one less step to follow and makes it easier in the long run. Now choose the arrow with the plus sign in the top left of Photoshop. This item will allow us to move the selection downward, at the same time it will be getting lower to the ground. Lower it but don’t lower it to much or else (like in real life the tires will be rubbing the inside of the wheel well( especially if you have bigger wheels in the picture)). And you can’t tell people that it has an air bag system especially if the picture can’t show it. The picture shows what I am talking about.
Step 3: Completing the picture
As you can see the vehicle has been lowered to the ground. Now you can deselect the picture. The vehicle is almost done. If you look at where you lowered it in the wheel wells you will see the black from the background. This area can now be filled in with a dark grey not yet a black. Use the Lasso tool again to select where you want to paint otherwise you will have paint in the wrong area and it will appear is if you rushed at it. Also add shadowing on the rims under the lip of the arch with the Dodge tool. Use shadow and highlights as your option around 50% opacity in the options bar at the top. Just like the picture below.
Finished Picture
Old Sep 12, 2010 | 07:19 PM
Red 96''s Avatar
I don't know how you are putting the pictures in, but they are really small and they arent clickable. But great tutorials by the way. I just used the wheel transfer one to do my first photoshop edit. Good job and thanks a lot!
Old Sep 12, 2010 | 07:51 PM
Thank you for the comment, the pictures have also been fixed. Thanks for the heads up.
Old Sep 12, 2010 | 07:56 PM
Red 96''s Avatar
Yeah, no problem!
Old Sep 12, 2010 | 08:12 PM
Next Tutorial will be tinting windows, color change ( the easy way), and Body kits.
Old Sep 12, 2010 | 09:01 PM
Red 96''s Avatar
Sounds awesome, they really are awesome and easy to follow
Old Sep 12, 2010 | 09:25 PM
TripleBlackBlazer's Avatar
PM sent about the picture size. Please take care of the issue.
Old Sep 13, 2010 | 03:08 AM
Pictures fixed, now clickable pictures. Sorry for such large pictures.
Old Oct 6, 2010 | 03:31 PM
BrutalSlide's Avatar
BrutalSlide is on a distinguished road
Great tutorial, although you can tell where you manipulated the background. To fix that you could use the clone stamp tool and copy parts of the bg to the parts that look different, to make it perfect.
butters
The Chop Shop
Jul 18, 2010 03:19 PM
Sisk
The Chop Shop
23
Nov 16, 2009 07:54 AM
EuroGoldLS
Mar 30, 2007 04:46 PM
JST4SHO
Mar 29, 2007 04:26 AM
02 Vortech
Jul 4, 2005 09:51 AM
