01' blazer OBDII error core P1637 ?
error code = P1637 i cleared it, and now it doesnt show up, but still not starting, turns over, just wont start. anyone know what this code means..? appreciate the input, thanks in advance
It seems to be a charging system error code...
here are a few descriptions:
P1637 Generator-L-Terminal Circuit
P1637 Generator Lamp Control Circuit
P1637 Charging System Lamp Control Circuit
Hopefully one of the guys with access to the dealership database can help you out with the diagnosis steps. I don't have my reference material with me at work.
ok, i figured out part of the problem, coil wire kept it from starting, it was arching on the back end of the engine, i re-routed it, and she suddenly came to life(at the turn of the key) i re-checked for codes, none are showing up, and the lights are no longer flickering(earlier post)... now, how do i get the dist. cap off, to replace it..? anyone..? i may as well do the whole shot, its time anyway.
The distributor cap has two torx bolts holding it down. One at the front and one at the back of the distributor. IIRC, it's a T15 bit that should allow removal. One word of caution, the screws do not stay with the cap, they can be dropped and lost so be careful when installing the new cap.
I currently have my intake off my truck right now so the distributor is sitting on my work bench. I'll snap a pic of everything for ya if you want.
ok, i changed all that, now it idles good, but once you take off, it cuts out, really bad, stop and put in park, smoothes right out. put in gear, cuts out..am i missing something here..?
Supercity
Feb 24, 2010 06:05 AM
theeviltwinn
Sep 16, 2009 08:18 PM
disturbedgame
May 8, 2007 10:32 AM
