1995 Blazer transfer case vacuum switch.
Old Mar 11, 2012 | 05:57 PM
Nicholas Smeed Jr.'s Avatar
Nicholas Smeed Jr. is on a distinguished road
Default 1995 Blazer transfer case vacuum switch.
My electronic 4 wheel drive hi and lo lights will not come on when I push the buttons. I checked the fuse and it's good. Will a bad transfer case vacuum switch and or hoses cause my lights not to come on and the 4 wheel drive system not to work?
Old Apr 2, 2012 | 12:06 PM
roadrageblp46254's Avatar
roadrageblp46254 is on a distinguished road
It might just be the light bulbs behind the switch
Old Apr 2, 2012 | 12:56 PM
50lb_cat's Avatar
When you push the button can you hear any click from behind the passenger side dash? You can pull your battery to start with. The vaccum actuator is under the battery tray. Look for tears in the diaphram and check the lines going back to the transfer case.
However, if you push the botton, hear a click but no light comes on that would lead to a bad selector switch. Or if the lights come and go. There is a great write up of diagnosing the system in the DIY section.
cjb2145
18
Oct 6, 2018 04:46 PM
scphill34
Apr 5, 2013 09:52 PM
kenlani
Feb 11, 2013 06:32 AM
paulp64131
Dec 26, 2011 03:52 AM
Chevy33
Jan 9, 2011 07:26 PM
