96 blazer 5-speed?
Old Aug 14, 2006 | 11:53 PM
Blazar1996's Avatar
Blazar1996 is an unknown quantity at this point
Default 96 blazer 5-speed?
is it possible to use a manual tranny from an s10 and put it in a 96 Blazer?
Old Aug 15, 2006 | 12:11 AM
Default RE: 96 blazer 5-speed?
If it's going into a Blazer with an auto tranny now, you'd have to have the PCM reprogrammed to work properly...
Other than that, you'd have to grab a tranny with the same drivetrain configuration as yours (ie. 4wd or 2wd).
Old Aug 15, 2006 | 01:40 AM
1996BZR's Avatar
1996BZR is an unknown quantity at this point
Yea, if the driveline configuration is the same and your blazer was originally equipped with a 5-speed, then it should swap out with no problem. That is, since the S10 and Blazer are pretty much the same vehicle. (yea, I know, one has a bed and one has to have the seats folded down to be a bed. But still, pretty much the same parts)
Old Aug 15, 2006 | 02:53 AM
blazin97's Avatar
blazin97 is on a distinguished road
As long as the s10 has a 4.3 then yes it will work. Thats where I got mine from.
Old Aug 15, 2006 | 09:08 AM
ORIGINAL: blazin97
Good call! Completely forgot about the 2put2.
Old Aug 15, 2006 | 05:08 PM
1996BZR's Avatar
ORIGINAL: swartlkk
ORIGINAL: blazin97
Same on my part. Forgot all about da four banger.
Pipewrench Dale
Nov 10, 2014 06:16 PM
jdub9000
Jul 22, 2013 07:58 AM
LuvBeej
Oct 4, 2008 12:29 AM
shutternot
Aug 3, 2005 07:57 PM
