ABS LIGHT
Old Mar 13, 2006 | 06:02 PM
1996BZR's Avatar
1996BZR is an unknown quantity at this point
Default ABS LIGHT
I have a 1996 blazer with a 4.3. For some reason the ABS light is always on. Is there an explanation for this problem?
Old Mar 14, 2006 | 04:28 AM
4lowlife's Avatar
Default RE: ABS LIGHT
Of course there is an explanation.
Any codes thrown? Buy a tech2 and it'll tell you even the bibles secrets.
Any other symptoms? Vibrating brake pedal during braking? It may indicate a bad wheel bearing.
Old Mar 14, 2006 | 11:23 PM
1996BZR's Avatar
I'll see about a tech2
Old Mar 17, 2006 | 05:52 PM
Hanr3's Avatar
The ABS light on is telling you that the ABS system has been disabled. In other words if you make a panic emergency stop, your ABS system will NOT control your braking and you WILL lock up your brakes, tires and skid to a stop. This means it will take you longer to stop. The ABS system prevents the tires from locking up and this helps reduce the stopping distance.
Now you need to find out why the ABS light is on.
What year is your truck?
Are you low on brake fluid?
Do you have All-Wheel ABS? Do you know?
There are several possibilites, however I don't feel like typing all the possibilities until I know more about your truck.
Old Mar 20, 2006 | 11:24 AM
1996BZR's Avatar
1996, brake fluid is fine, not sure about all-wheel abs, but i think it is .
Old Mar 21, 2006 | 06:31 PM
Hanr3's Avatar
The likely candidate is a bad/dirty sensor. Search the site. I saw some info on how to pull the codes for the ABS system.
Old Mar 29, 2006 | 04:00 PM
STEVE1103's Avatar
STEVE1103 is an unknown quantity at this point
What is a Tech2, and were do you get it, all the code reads I checked don't give you the ABS codes for trucks?? Thanks
Old Mar 29, 2006 | 04:34 PM
A Tech2 is a scanner used by the dealerships. It costs ~$1800. Not just something you are going to run out and purchase.
Old May 12, 2006 | 06:21 AM
PawNtheSandman's Avatar
PawNtheSandman is an unknown quantity at this point
where is the abs sensor located?
Old May 12, 2006 | 08:11 AM
ORIGINAL: PawNtheSandman
Welcome back! It's been awhile since you've been around.
Anyway, from looking back, I found out you have a '98 2dr 4x4. There are ABS wheel speed sensors in each of the front hubs and I believe that the EBCM (electronic brake control module) monitors the transmission output speed sensor for the RWAL (rear wheel anti-lock).
