ABS LIGHT
Old May 12, 2006 | 10:02 AM
hdlogistics's Avatar
hdlogistics is an unknown quantity at this point
Default RE: ABS LIGHT
I had some rust on my sensors causing the light to flash every now & then. Once I cleaned them, no more light issues.
Old May 12, 2006 | 10:47 PM
PawNtheSandman's Avatar
PawNtheSandman is an unknown quantity at this point
Reason I ask is because I have all new brakes, but the ABS light is now on.
I have my Haynes manual, but the pictures suck. Could anyone provide me with a picture of what I should clean. Also which fuse should I check.
TY
Old May 12, 2006 | 11:02 PM
Actually, I think I might have been mistaken... I believe that the sensor is in the steering knuckle not actually part of the wheel bearing/hub. The area to clean would be the end of the sensor and the reluctor ring on the front driveshaft if you have a 4x4, but I do not know how the ABS sensor is on the 2wd models.
Tinted
Mar 15, 2012 02:56 PM
damageinc98
Jul 12, 2010 10:47 PM
stormshadow1
Apr 23, 2009 09:46 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
