biggest engine in a 2000 4 door
Old 08-30-2007 | 05:53 PM
cowboy717's Avatar
cowboy717 is an unknown quantity at this point
Default RE: biggest engine in a 2000 4 door
i dunno if the IFS would be able to handle the weight of the 4BT cummins, they weigh about 700 lbs,, now if your gonna go SFA,, oh yeah,, i'd do that in a heartbeat,
and yes i know that the LS engines are small blocks....
how much would it take to make them work?? with the electronics and stuff??
  #22
Old 08-30-2007 | 06:16 PM
drperry's Avatar
You'll need a hammer and engine mounts... but the hard part will be the electronics for the LS series...
  #23
Old 11-06-2007 | 01:40 PM
blazinblack's Avatar
blazinblack is an unknown quantity at this point
any small block gm would fit and with the right motor mounts would work i want to do a small block 400 or 383stroker
[align=left] [/align]
  #24
Old 11-06-2007 | 02:07 PM
myol blue4x4's Avatar
myol blue4x4 is an unknown quantity at this point
Can you say 454? Found this beauty on cardomain...
http://www.cardomain.com/ride/2535980
  #25
Old 11-06-2007 | 07:30 PM
drperry's Avatar
Looks good... But I don't know if it's an S-series frame under that body, lol
  #26
Old 11-06-2007 | 08:44 PM
No its a half ton pick up frame with 3/4 ton axles, quit a beast lol.
  #27
Old 11-06-2007 | 08:50 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Looks like it needed a little front end work too. Im certain that grille aint sittin right and the bumper looks a little rashed. Good news is that thing is for sale, and for cheap $5000 takes it according to what it says.
  #28
Old 01-20-2008 | 11:49 AM
welder1550's Avatar
welder1550 is an unknown quantity at this point
what about a 5.3 L vortec? is this a good swap?
  #29
Old 01-22-2008 | 04:59 AM
blazerbeam's Avatar
blazerbeam is an unknown quantity at this point
350 swap requires new engine mounts and a new flywheel
everything else should bolt up
  #30
Old 01-22-2008 | 05:30 AM
thegr81's Avatar
As far as doing a ls motor swap there is a kit for doing it that comes with new motor mounts and all the adapter plugs needed to plug and play with the motor, also if they can stuff a 572 in a caddilac cts cowl hood you can put one in a blazer!!
http://www.youtube.com/watch?v=z2lM5SdMVlc
