Cam Help Please
Old May 5, 2009 | 09:20 PM
PaulO2288's Avatar
PaulO2288 is on a distinguished road
Default Cam Help Please
I just bought a 99 Blazer 4 Door and i had to pull the stock motor due to a bad rod bearing. So to the new motor im doing a few things to get a little more out of it. Im looking into getting headers, My dads friends shop is makeing custom dual super 44 exhaust for my truck, a 180 thermostat, K and N Cold Air Intake, and a cam. I called Summit Raceing and a slight upgrade from the stock cam with a programmer is $700. Anyone know where I could possibly get one cheaper? Thanks
Old May 6, 2009 | 01:26 AM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
i would check Crane Cams, i have only heard good things and i have had good luck with them in the past. they have pricing on there website but im not sure off the top of my head what you would be looking at.
Old May 6, 2009 | 06:57 AM
You will need a tune, an actual custom tune, not just a programmer for everything to work to its maximum safe potential.
I have used the tech line for both Comp Cams and Crane Cams. Both are excellent and can direct you to the proper cam selection based on your expectations and proposed modifications.
Stettenbenz07
Performance & Brainstorming
Oct 10, 2015 08:47 AM
95 S10 Blazer
Engine & Internal
Mar 20, 2010 07:59 PM
rogggg1020
Nov 11, 2008 08:05 AM
95blazer4wd
Sep 18, 2008 10:38 PM
Junkyard Dog
Engine & Internal
Feb 25, 2006 04:44 PM
