do i need a new v8
Old Nov 13, 2010 | 02:49 AM
itsalwaystime420's Avatar
itsalwaystime420 is on a distinguished road
Default do i need a new v8
ok ive been reading and i see that a v8 will fit in and bolt up to the stock tranny but do i need a newer v8 or does the year matter if so my blazer is a 95 what year motor would give me the least amount of headaches during install
Old Nov 13, 2010 | 11:40 AM
oktain's Avatar
using a 95 5.7L (350CI) from a silverado/sierra/fullsize whatever would give you the least amount of heartaches. Computers match up, everything.
Keep reading, you'll need swap mounts, headers (2wd and 4wd headers are different) etc.
Old Nov 13, 2010 | 03:49 PM
69chevelle's Avatar
69chevelle is on a distinguished road
tons of info out there. it's not a hard swap. goodle s10 350 swap, you will get lots of good links for info/parts/etc.
one part I found hard to figure out is a 4wd you need a conversion oil pan, unless you use the advance adapter 4.3 conversion mounts. but you will need a cowel hood or body lift for that, as the motor gets raised up a bit
I would reccomend the mid 80's camaro 305 manifolds, unless your looking to get the most hp you can out of it, due to clearence reason's, they fit easier then the conversion headers.
google the crap out of it,
this is one reference link I have bookmarked, I am still up in the air if my jimmy will be getting a 350 when the snow is finished
http://www.marquisphotos.com/ZR2_Blazer/V8ZR2/6.htm
2wd's are a lot more clearance friendly.
newguy
Mar 28, 2015 02:38 PM
hedgepig
Oct 17, 2010 10:18 AM
Fat_Phil
Sep 10, 2008 08:34 PM
yazan84
Dec 30, 2007 11:19 PM
thegr81
Oct 19, 2007 08:18 PM
