Fuel system problem
Old Nov 12, 2005 | 11:49 PM
codereddanger84's Avatar
codereddanger84 is an unknown quantity at this point
Default Fuel system problem
Hey guys im new here and i need some help. Okay my blazer will start for about 1-2 minutes then it dies and it wont start for another couple of hours. Just replaced the fuel pump and filter a week ago. Im completly stumped now. Turn the key to the on postion and i can hear the pump turn on, then pulled the fuel line off the filter on the engine side got covered in gas so its not clogged. I checked those then i got it to start at idle the passenger side injector was a little clogged but was fine once i reved the throttle a little bit. It ran for about 2 minuets then it stopped getting gas, so i loosend the fuel line to the back of the throttle body to see if there was still pressure in the line and there was. I dont know were to go from there. If anyone has any thing else to try i'll give it a shot. Thanks for the help guys.
PS: does anyone have a exploded view of the throttle body or know were to get one from. Thanks again
Old Dec 2, 2005 | 02:09 AM
02 Vortech's Avatar
02 Vortech is an unknown quantity at this point
Default RE: Fuel system problem
umm im not sure but i could be something having to do with the spider distributer for the fuel injectors- Take your question to s10forum.com/forum they will have answer for you right away (post it in the 262 c.i. forum)
Old Dec 2, 2005 | 10:05 AM
It would help to know what year we are talking about here. It almost sounds like a security system problem where it can not verify the key and kills the motor. It could be something as simple as reprogramming your key to the truck (requires a dealer I believe) or it could be that the ignition is bad (place where the key goes). Both have been know to happen from time to time.
If you have verified fuel, then I doubt that it has anything to do with anything from the fuel taps at the intake back to the tank. Like I said, depending on the year, some of the newer blazers have an anti-theft system that could be malfunctioning in your case.
rafesmom<3
Jun 23, 2011 04:12 PM
liltittle62
Dec 26, 2010 03:55 PM
Mudd8227
Nov 19, 2009 08:32 AM
mtnwomanar
Sep 23, 2009 01:07 PM
joethejman4us
Jun 4, 2009 01:01 AM
