hesitation at the stop
Old Jan 25, 2006 | 07:45 PM
thebaf's Avatar
thebaf is an unknown quantity at this point
Default hesitation at the stop
2000 blazer 4.3 vortec..had new wires,dist cap,fuel pump,and injectors cleaned,still randomly hesitates at a full stop wet ,dry morning or evening.any thoughts? any ideas?thanks
Old Jan 25, 2006 | 07:48 PM
4lowlife's Avatar
Default RE: hesitation at the stop
Hesitates as in what? bad idle or slow to accelerate?
Old Jan 26, 2006 | 03:25 PM
thebaf's Avatar
when you give it the gas the engine jerksaand sputters,never stalling, before it takes off
Old Jan 26, 2006 | 03:35 PM
Sounds like the EGR valve is stuck. Pull it off and give it a good cleaning with some sensor safe carb/throttle body cleaner. Get a new gasket and slap it back together. If you can see carbon buildup in either of the ports where the EGR bolts on, try to clean out these ports because that will only flake off and clog up the valve again.
Old Feb 9, 2006 | 08:45 PM
blazingsadle's Avatar
blazingsadle is an unknown quantity at this point
Agree with the egr valve. Have a form of cleaning the intake out that I am scared of and only use in EMERGENCIES, but will proceed to mention. Making sure NO ONE ELSE is near car, and you are in drivers seat, protected. Remove egr and try to start engine, if it runs, shut it down quickly. All kinds of junk will fly out, all over the place. Cleaning this up will take a while if you didnt cover things a bit. Like I said, desperation makes for strange aproaches. Seafoam like mentioned in other posts will keep intake a lot cleaner. Yes the egr will still also needs cleaning.
Old Feb 9, 2006 | 09:10 PM
4lowlife's Avatar
I like that little fix. Should he disconnect the harness from the EGR? What will fly out? carbon and black smoke? I just might try that too. Outside of the barn of couse!
Old May 18, 2006 | 01:08 AM
meggles's Avatar
meggles is an unknown quantity at this point
can anyone tell me were the EGR valve is. My 93 blazer is running like crap and everything points to the valve. but I can't locate it. Its a girl thing
dannyb91979
Jul 16, 2013 06:08 PM
InsideTheseArms
Jun 19, 2006 05:52 PM
lovetheblazer
Jan 30, 2006 11:12 PM
Ricksastar
Apr 24, 2005 07:05 PM
tambo
Mar 4, 2005 05:44 PM
